Introduction: Homemade Guitar
Picture of Homemade Guitar
This is the first guitar that I've made, I plan on making more. I did this one in my in my high school woods class. I'm sorry I don't have any step-by-step instructions, but if you have any questions just comment and I'll answer them as soon as I can. The guitar is completly handmade, except for the pickguard, which I machined with a CNC router.
BadAssAnna (author)2013-12-28
Hey um do you know if it is possible to find instructions on how to build a guitar on the internet?
If you do know would you tell me?
wooddiamond (author)BadAssAnna2013-12-28
I found a book at my library that had instructions, but I have since moved and my new library doesn't have anything :( you can buy books on amazon and there are other instructables that have good advice like, Machine Your Own Guitar by mattthegamer463, Build Your Own Electric Guitar! by gbuilder, and How to build an Electric Guitar. by friger. sorry I don't know a specific place where you could get instructions online, i can help if you have any questions, good luck
BadAssAnna (author)wooddiamond2013-12-31
Ok! Thank you! I have always wanted a guitar, but they cost to much but now I can make and design my own guitar. THANK YOU!
wooddiamond (author)BadAssAnna2014-01-01
Your welcome. Like I said if you have any questions feel free to ask.
Bjarke (author)2013-11-06
Did you treat the steel in any way?
wooddiamond (author)Bjarke2013-11-06
The pickguard piece? It's actually aluminum, I didn't treat it in any way.
Bjarke (author)wooddiamond2013-11-07
So you just cut it out and drilled holes? Cool!
wooddiamond (author)Bjarke2013-11-07
Yup thanks, but I used a CNC router, it did all the work :) I just designed it.
dkeach (author)2013-08-11
did u use a steel rod in the neck under the fret board for reinforcement or is it just solid wood, also did u also repurpose the pickups?
wooddiamond (author)dkeach2013-08-11
I did not repurpose the pickups. I didn't put a truss rod :( which I now regret doing, I highly recommend putting in a truss rod if at all possible.
dkeach (author)wooddiamond2013-08-11
Why is that? Im considering doing an adaptation of the custom vox that lennon and harrison shared. What have u experienced without the truss rod that having one would fix?
wooddiamond (author)dkeach2013-08-13
Without a truss rod the neck will bend, from the tension of the strings, increasing the action and eventually will make it almost impossible to play the guitar
daxident (author)2013-05-05
How did you build/make the neck?
wooddiamond (author)daxident2013-05-08
The neck is three strips of wood that run through the body( I took the fret board off a old guitar).
Penolopy Bulnick (author)2013-05-03
That is amazing! Did you cut out the metal plate too?
Yes, I designed it with a CAD program< and machined it with a CNC router
KyleF4 (author)2015-08-27
I see you took inspiration from the Epiphone SG for the body of the guitar and the Stratocaster for the pickgaurd. You should dremol in something like Sgatocaster into the head, which looks awesome by the way. Keep up the good work.
wooddiamond (author)KyleF42015-08-27
Thanks Kyle and youre totally right
About This Instructable
6,660views
47favorites
License:
More by wooddiamond:Custom wood puzzleHomemade Guitar
Add instructable to:
