Step 11Glue Top Cover Into Place
Put the rubber down, "nice" side down, and put the plate on top of it. You're going to need to fold the rubber over the edge of the plate and glue it into place in sections. I found 2 hours is the "right" amount of dry-time before you can move to the next section.
I first folded over a section of rubber, then traced on the plate with the marker where it sat. I did this so that A) I knew where to put the glue, and B) once I was ready to clamp, I knew where the edge of the rubber should be. Next, squirt some of the glue onto the plate using the trace line as a guide.
The order may or may not really matter. I did a "back-and-forth" sort of pattern. First one section, then the section on the opposite side. Then the next section as far away as I could get to where they were already glued. This way, you get more 'even' coverage.
After it's done and dry (and not before!), cut the small mounting hole in the top. I used an Exacto knife, you can use whatever you have. It doesn't have to look perfect; it'll get covered up when we mount it.
Add Comment
