3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Guitar Hero World Tour Cymbals (New and Improved!)
Step 15Glue Piezos Into Place
Armed with your new found knowledge, feel confident in gluing the final pieces into place. First glue the small rubber circle to the plate, then slap some glue on the top and glue the Piezo to it.
Another opportunity to learn from my mistakes... I got overzealous and glued these pieces down before I tested as thoroughly as I should have. I glued them to the center of the plate, and later that night when I sat down to jam, found that I couldn't hold a fast beat on the yellow cymbal to save my life. As it turns out, with the piezo in the center of the plate, there were two problems:
1. If the sensitivity was too low, it only worked when you hit the plate in the center, where the piezo is...
2. If the sensitivity was too high, the piezo was close enough to the mount that the other drums would trigger it when they weren't supposed to.
A little more testing (after ripping the glued piece up) showed that the proper location for the piezo is bottom-center.
I decided to use the electrical tape long-term to cover the piezo with. I would still like to be able to get at the little sucker if I need to in the future...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jmrank
