3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Guitar Hero World Tour Cymbals (New and Improved!)
Step 6Remove Plate Ridge
Remove Plate Ridge
Turn the plate upside-down. Notice the inner section of the plate, how it's so much higher than the outer ridge? We want to round that out, so there isn't so much of a "corner" that the drumstick could hit whilst we rock.
I decided to just build that outer section up, so that the final layer of rubber would be more "rounded." Start by tracing the outer-rim of the plate, just over 1/4 of the way around. Cut that piece with some nice sharp scissors.
Don't use the kitchen shears like I did. They're great, but it left red Sharpie ink all over the blade. My wife was none too pleased with that.
Once you've got the outer line cut, put the piece on top of the plate and trace as best you can where the inner ridge is, and cut the piece out. It should look about like the second image. In the interest of mass-producing, keep using the plate for the outer edge, and use the first piece as a pattern to cut out 7 more pieces just like this (you'll need 4 for each plate).
Glue them onto the plate, as seen in the 3rd image. I put one layer on each plate, and figured the inner ridge was still too high, so I put a second later more on the inside. Put them as close together as you can, but it doesn't really matter what it looks like, since this will all be covered up anyway.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jmrank
