3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Guitar Slide
Many of you are probably not wondering: HAL, what did you do when you forgot to get one of your two friends a christmas present? Well, since he is into bluegrass guitar, I gave him one of these, which he mistook for a piece of broken glass.
This is how to make your own professional looking glass guitar slide from a bottle to get that nice, authentic bluesy sound, or to play any number of other types of music. This is a very easy method of making a great tool for guitarists, and makes great, cheap gifts for your guitarist friends.
Step 1Gather Materials
Gather Materials
For this project you will need a few materials and tools. You will need:
One bottle. This should have a very pronounced neck, unlike some beer bottles which just taper slightly to the top. The project will work best if the neck on your bottle has a long, straight section, like a wine bottle.
Glass Cutter. If you don't have one, get one. I got mine for i think $3.50 at the hardware store, and its very useful if you're into DIY. This is essential to the project.
Sandpaper. You could rub the glass on the wet sidewalk, this also works. I use a combination, since the sidewalk is rougher than my sandpaper.
You may also want gloves, since there is a guaranteed potential for broken glass. hearing protection is also advised, since there is also a potential for loud noises.
41 comments
1-40 of 41next »
Jan 3, 2012. 1:04 AMguitarfan says:
i found out that this is simpler with a dremmel tool and only takes 10 minutes, you have to wear eye protection unless you dont like to see
Jan 17, 2011. 11:13 AMAcorns says:
Very good HAL, i'l be making one soon ;-)
Nov 23, 2010. 10:55 AMJoe Steelheart says:
Copper slides r cool Wwipe down your guitar and y strings each time you play W #10 copper pipe. a vise, a file and a hacksaw, = (15) 3" slides for $10.
Rule #1 - Don't park a copper slide in your mouth, - poison
Rule #2 - Don't water it with your plants, it kills plants
Rule #3 - Keep it away from toddlers who put everything in their mouths, or
brother you will really get the blues.
Copper slides are light, fast and straight. How to play decent slide with a fat bottleneck with a lip or screwmount on it? DA could do it. I used to use dunlop glass slides, expensive. I kept breaking them when they fell out of my shirt pocket. The difference between the Dunlop and the homemade (copper) slide is wheh you put your plastic thumb and fingerpicks in the Dunlop slide, they fit perfect and stay in.
May 21, 2009. 8:40 AMNassmaster says:
HI there, first ,thanks a lot for sharing this... can you tell me about the min/max Slide length ? cheers.
Aug 6, 2010. 7:14 PMEigenbroetler says:
Well Nassmaster, you asked this question more than a year ago, but I figured I'd try to help anyway. I'm not sure if there is a standard length, but you want it to be as long as your fingerboard is wide. You could measure your fingerboard at the widest point and try to make your slide that long. OR--you could just make it 2-5/8 inches... because that's how long my store-bought slide is :). I dropped a Corona bottle a few weeks ago and the neck broke off, and it just happened to be 2-3/4" at the shortest point, so perhaps I'm in luck! Thanks HAL for the tutorial!
Aug 7, 2010. 5:58 AMNassmaster says:
Thanks Eigenbroetler, By the way, I found that 3 inches or a little bit less was just perfect for me. keep sliding ;)
Mar 4, 2009. 6:04 AMbeauwalker23 says:
Sweet man! Now all i gotta do is down my wine bottle! cheeers!
Aug 6, 2010. 7:15 PMEigenbroetler says:
This could possibly be the most fun part of the project. Just don't make the slide until a good 6 hours later.
Jun 3, 2010. 12:14 PMSt.Louis says:
Hehe, I (or one of my friends) made one of these when I was drunk once. Accidentally that is. After a big party I found a broken bottle of passoa in the yard. The neck was still pretty much intact, and it was perfect as a slide.
The sanding isn't really necessary, just put the other end on you finger ;)
Dec 19, 2009. 10:12 PMfireman115 says:
What do i do if i dont have a glass cutter?
Feb 4, 2010. 2:02 PMRatRag99 says:
 A hacksaw works well, but it takes patience. And glass breaks easily even if its a tiny cut. So really, just score the bottle with the hacksaw and then hold the neck and tap the bottle against a hard surface. It will break off right around your scoring mark and then you can sand down the edges.
Feb 1, 2010. 6:50 PMS Timmerman says:
I make and sell them VERY reasonable on my site -   I'll have more very soon  - I keep running out as I sell them at such a good price.  If you want a bunch contact me.    Or a certain color, with something painted on them ect.  I'm an artist.
Aug 31, 2009. 12:00 AMlusoc says:
Another trick is to heat the score line over a candle and then immediately plunge it under cold water. This is much less violent and produces good results.
Jun 23, 2009. 10:21 PMsammydiy09 says:
I've got to try this!!
Apr 17, 2009. 5:58 PMestefistefis says:
Hey!! thanks a lot! i'm a guitar player and yeaH! this is gonna help me ;) greetings ;
Jan 13, 2008. 6:19 AMlennyb says:
good job. this is a similar method to how i made my own slides the main difference is i heated the scored line with a candle then rubbed the line with an icecube. the thermal shock cracked the glass and the neck came off in my hands with no need for thumping and banging. it also preserves the rest of the bottle for if you want to make a vase or something
Feb 21, 2009. 2:04 PMmdog93 says:
i used this method and it worked well apart from my line wasn't very straight in the first place but i just found a new way of doing it without having to scratch/score a line, the video is here: http://www.metacafe.com/watch/508368/how_to_cut_a_glass_bottle/
it's basically the same as lenny's way but instead of scoring a line yoa wrap a line of thread around put lighter fuel on the thread burn it til it goes out then put it in water! really impressive
might give this method a go
mdog
Feb 22, 2009. 4:44 PMlennyb says:
oh yeah i`ve seen that way . it works really well if you give it a nice clean burn with the fuel primarily on the thread. if its all down the glass you wont get a predictable cut.
Feb 12, 2009. 7:31 PMsmash10101 says:
wow, I wish i had thought to look for one of these earlier. I put a bottle in a vice and tried to cut it with a hack saw. BAB IDEA. I got bored and tried to chisel it, but the bottle moved, 5 sec later It randomly exploded. DO NOT TRY THAT WITH OUT HEARING PROTECTION AND GLOVES AND GOGGLES. This makes it a lot easer, now I just need an excuse to drink a bottle of wine, to bad I'm under 21.
Jan 29, 2009. 10:57 AMmdog93 says:
do you think this groove will be roughly deep enough, because i did it with a file as somebody said you could in a comment. I know it's probably hard to see because the pictures were quick and rough but you will know better than me wehther it's good enough. thankyou, mdog
Jan 15, 2009. 2:07 PMchimpanzeeboy says:
I've just bought a glass cutter off ebay, i'm trying this as soon as it arrives :D
Jan 7, 2009. 11:49 AMwoodfinery says:
Wood FineryEnjoyed the easy to follow steps on building a homemade slide. Now I have something to do with the empties!
May 14, 2008. 3:47 PMtreefrogjohnson says:
haha nice. My dad and I were walking around Home Depot and found little copper tubes in various sizes that looked perfect for guitar slides. We each got one that fit us and tried them out. It works pretty well! I don't know the advantages of glass over copper though, or even if there are any disadvantages of using copper. But for 60 cents or so, you can't beat it.
Jun 17, 2008. 8:58 PMEsmagamus says:
Copper might get some oxide on your strings. Watch out they dont' get green and stain your guitar. You might consider polishing, coating with oil without touching it and leave your slide alone for a few weeks. Works on brass.
Jan 6, 2009. 4:44 AMtravisrichardson1980 says:
my strings are copper wound, so i'm not sure the slide would hurt them. copper stained fingers are hard to clean, though.
Sep 29, 2008. 7:06 PMrickymojo says:
Son House used copper slides. If its good enough for him, its good enough for 99.99% of guitarists, eh? If you wear copper jewlery all day and or night it turns your skin green. If you play an hour or so a day, no green my friend. Direct knowledge is the only knowledge that is true. Ruin your strings, stain your guitar? Anyone had this happen? You better take the penny out yer pocket, it may stain your pants. Think about it. Or experience it, even better. Peace.
Jul 16, 2008. 7:32 PMtreefrogjohnson says:
Thanks for the tip. We don't use it often, so there's no real worry. My dad plays more lead than anything, and I play bass. Hopefully we'll be picking up some DR Coated Strings soon. That should ease the wear of whenever we do use copper slides. Though I may make a glass one soon.
Jun 5, 2008. 12:12 AMRishnai says:
It's just a sound difference. Probably harmonics or something. You can listen to some blues records and tell right away, "Hey, that guy had a glass slide!" or whatever. I've used some plastic slides before, and they really have a bad sound to my ear. Both store-bought and homemade ones. Glass seems to have what I would call a softer edge to it than copper. Kinda like the sound difference between your guitar's tone knob set at 0 or set at 10, or bridge versus neck pickup. Same kinda change.
Jun 5, 2008. 9:16 PMtreefrogjohnson says:
Yeah, I see what you're saying. I'll probably try different ones out and mess and switch around just to experiment with different sounds. That's always fun. My dad had a glass one, but I'm not sure where it went...
Jun 5, 2008. 10:38 PMRishnai says:
It really is amazing how one small change can make a big difference.
Sep 14, 2008. 3:57 PMslucepan says:
A diamond blade in a hack saw frame works well to cut off bottle necks.
Jun 17, 2008. 8:55 PMEsmagamus says:
Nice. I once had a surplus piece of shiny stainless stell tubing around here and just wrapped a layer of cotton adhesive bandage on each end. Loos good, and gets the work done.
Apr 15, 2008. 9:11 PMTheMadTinker says:
Nice instructable, tools definitely make making a bottleneck slide easier. When I made mine, I just dropped a bunch of wine bottles trying to figure out how best to break them so the neck stayed intact, eventually discovering that the best way to do this is to hold the bottle sideways, parallel to the ground, and drop it from about 1.5 feet, then you can just grind down the sharp edges on the sidewalk.
Mar 6, 2008. 7:26 PMtransmothra says:
Way awesome! I always assumed that they were worn the other way around.
Feb 17, 2008. 11:49 PMYerboogieman says:
one time i used a wrench, a speaker box, an altoids can, an AOL CD, my digital tuner, and my PSP, this way is probably alot better
Feb 9, 2008. 7:29 AMcarpespasm says:
You can also use a torch to smooth the edge and give it a nice shine, just be sure to warm it up slowly or you might crack it like lennyb's scoring and shocking.
Feb 8, 2008. 2:12 PMMark Rehorst says:
You can use a metal file to cut the glass too, so don't buy a glass cutter if you have a metal file in your tool box already. Bourbon bottles make the best sounding slides for playing blues. Wine bottles are for classical music. TD
Jan 12, 2008. 11:04 AMGorillazMiko says:
Too smart. People use bottles for slides, and you just made it easier, nice job, I might do this some time... +1 rating. (added to favorites)
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:HAL 9000
I'm working towards a Bachelors Degree in Mechanical Engineering at Oregon State University.
