3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Guitar Slide
Step 2Cut around the neck
Cut around the neck
In this step we will cut the bottleneck, which will become the slide. for this you need to know how to use a glass cutter.
A glass cutter does not actually cut glass, rather it scores a "weakest link" line into the glass which, when the glass is broken, will redirect the direction of the breaking along the scoring line.
To use your glass cutter score a line around the neck applying pressure with the cutting wheel along the glass, like in the picture. Try to make just one, straight line to get a good, clean cut.
3 comments
May 21, 2009. 8:40 AMNassmaster says:
HI there, first ,thanks a lot for sharing this... can you tell me about the min/max Slide length ? cheers.
Aug 6, 2010. 7:14 PMEigenbroetler says:
Well Nassmaster, you asked this question more than a year ago, but I figured I'd try to help anyway. I'm not sure if there is a standard length, but you want it to be as long as your fingerboard is wide. You could measure your fingerboard at the widest point and try to make your slide that long. OR--you could just make it 2-5/8 inches... because that's how long my store-bought slide is :). I dropped a Corona bottle a few weeks ago and the neck broke off, and it just happened to be 2-3/4" at the shortest point, so perhaps I'm in luck! Thanks HAL for the tutorial!
Aug 7, 2010. 5:58 AMNassmaster says:
Thanks Eigenbroetler, By the way, I found that 3 inches or a little bit less was just perfect for me. keep sliding ;)
Dec 19, 2009. 10:12 PMfireman115 says:
What do i do if i dont have a glass cutter?
Feb 4, 2010. 2:02 PMRatRag99 says:
 A hacksaw works well, but it takes patience. And glass breaks easily even if its a tiny cut. So really, just score the bottle with the hacksaw and then hold the neck and tap the bottle against a hard surface. It will break off right around your scoring mark and then you can sand down the edges.
Jan 29, 2009. 10:57 AMmdog93 says:
do you think this groove will be roughly deep enough, because i did it with a file as somebody said you could in a comment. I know it's probably hard to see because the pictures were quick and rough but you will know better than me wehther it's good enough. thankyou, mdog
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:HAL 9000
I'm working towards a Bachelors Degree in Mechanical Engineering at Oregon State University.
