3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Guitar Slide
Step 4Smooth out the Edges
Now you basically have a lovingly crafted weapon suitable for a prison/barroom fight. If you want this, set it aside, start over and continue with what will be your slide. It's time to get rid of the sharp edge.
You may wish to wear gloves for this as well.
Scrape the edge of your bottleneck on some smooth pavement. It will help it it's wet. Grind it at different angles to round out the broken edge until you can see that it is no longer sharp. If you wish to get a smoother edge, proceed to sandpaper and smooth as much as you like.
If you don't have access to some smooth pavement use sandpaper, since it works just as well, but not as quickly. Sand inside and out, leave no sharp cutting edges.
I prefer the rougher look and I only use sandpaper on the inside of the edge. I'm sure if you worked your way to finer sandpaper and polished, perhaps with a Dremel tool, you could get a nice, factory-looking edge on it. Since this is homemade, I'm fine with the homemade look.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:HAL 9000
I'm working towards a Bachelors Degree in Mechanical Engineering at Oregon State University.
