This is a bike light I have made because of the fact that the commercially made versions are way too expensive for my needs and I thought it would be fun to make! I'm using a 20W 12 volt bulb and two R/C car batteries rated at 2000ma/h and are 7.2 volts each. I linked them in series to double the voltage so effectively I'm 'overvolting' the bulb which does in turn reduce the life span of it!
Check the photos for a more detailed insight on how its put together-------
Step 1The Bulb Casing
The bulb casing is actually a piece of PVC piper joining and some how fits perfectly with a halogen bulb when the end cap is screwed on (cap not shown here)
I used a bolt with a square shoulder for the clamp so that it didn't spin inside the casing, the hole in the piping was drilled out then the square was formed with a sharp craft knife.
1) might be a year late ....can you please advise on run time for this light in terms of hours or total minutes.
2) in terms of one 7.2v battery ...whats the rating of the wattage output >?
many thanks.
I think its just a pipe clamp, can't remember the size of it though, made out of brass. All the holes are threaded too. I reckon its just for household copper piping so just look in your hardware store and something similar will probably be found in the plumbing section perhaps.
Cheery ho,
Sam
I might try and work from that!
