3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Halogen Bike Light
This is a bike light I have made because of the fact that the commercially made versions are way too expensive for my needs and I thought it would be fun to make! I'm using a 20W 12 volt bulb and two R/C car batteries rated at 2000ma/h and are 7.2 volts each. I linked them in series to double the voltage so effectively I'm 'overvolting' the bulb which does in turn reduce the life span of it!
Check the photos for a more detailed insight on how its put together-------
Step 1The Bulb Casing
The Bulb Casing
The bulb casing is actually a piece of PVC piper joining and some how fits perfectly with a halogen bulb when the end cap is screwed on (cap not shown here)
I used a bolt with a square shoulder for the clamp so that it didn't spin inside the casing, the hole in the piping was drilled out then the square was formed with a sharp craft knife.
16 comments
Jul 21, 2011. 6:41 AMmoss_russell says:
hi there
1) might be a year late ....can you please advise on run time for this light in terms of hours or total minutes.
2) in terms of one 7.2v battery ...whats the rating of the wattage output >?
many thanks.
Sep 24, 2010. 10:26 PMBrian_B says:
Do you know what that type of clamp is called? I have not seen one made like that. It looks very strong.
Sep 25, 2010. 12:27 PMBrian_B says:
Thank you. I will look in the local hardware store. That gives me a good idea of where to look. :)
Oct 22, 2008. 8:59 PMYerboogieman says:
i like this, high mA, potencial for lightweight, but im sorry, sticking to my halogen cygolight
Jul 7, 2007. 4:37 PMLoveofchaos says:
this might have a place mounted above the caltrops deployer lol
Feb 11, 2007. 12:48 PMlemonie says:
I did something similar to plug into the "12V" electrics of a Honda Caren (50cc twist 'n' go moped). I found that the bulbs were overdriven & didn't last too long, but you're not going to get much more than an hour out of your battery? See pic:
Feb 11, 2007. 12:50 PMlemonie says:
...and I would post an instructable, but there's no way I'm doing all that papier-mâché again...
Jan 30, 2007. 9:16 PMGreenDay says:
By aiming it properly, you mean directly at the windshield? You can't really blind a car, more like the drivers, my bad. As to how legal riding into oncoming traffic is, what if you we're riding the right way down a one way street, and some driver came the wrong way along the street, technically, you'd be running into oncoming traffic legally... I stand by what I said with the 500w bulb...
Jan 29, 2007. 7:04 PMTrans_Am says:
I think you mean you wired it in SERIES to double the voltage. Parallel wiring would double the battery life. You mentioned that in the intro.
Jan 29, 2007. 7:08 PMGreenDay says:
My suggestion would be to avoid this wussy light, and hook up 25 r/c car batteries with a 500w halogen light. That way, you can blind oncoming cars. You could possibly also hook them up to a motor for added speed. Good instructable, what type of batteries are they? Please tell me Li-Po, this would be a good use for left over Li-Po batteries, now that most races don't allow them, as they tend to explode...
Jan 29, 2007. 11:29 PMtrebuchet03 says:
Something tells me that if I were riding into oncoming cars (which would be illegal) ... I wouldn't want to blind a high velocity 2 ton hunk of metal/plastic/etc. I think someone else used high wattage bulbs -- just aim your lights properly :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:smegger
