Homemade Hydroponic Bucket System
Published
Introduction: Homemade Hydroponic Bucket System
How to build a.cheap diy hydroponics system
Step 1: My First Build
Expandable Hydro Tub build
Double Bucket System
this is a homemade built version of an expandable hydroponics tub for a cost to build of 100$ est. (pump and parts prices vary)
list includes recycled parts from around house to buying simple cheap affordable pumps and +/- air stones with plastic tubing drip emitters.
- for a 4 bucket system that is easy to expand for more and other options
-4 plastic coffee cans preferred with plastic snap on lids
-4 plastic 4" or 6" net cups ( I made ones out of 6 " pots and cut extra holes for net)
-approx 10 ft of 1/4" water emitting tubing + 4 drip emitters and stakes. Some 1/4" t's and elbows
-approx 1ft 1/2 " black water line.
-1 plastic tote (roughneck ) blue (paint it black then white also paint coffee cans too)
-2 pumps one submersible other air pump and stones
Some assembly required LOL...
1 - wash and clean all plastic buckets and pumps (1 time a week) AND at first set up clean coffee cans very well with soap and water bleach works too.
2 - I used a chainsaw file heated up to poke holes through side coffee cans near bottom. (I did leak test and it worked :) )
push 1/4" water tube into bottom of coffee and connect to a 1/4" T and connect to other coffee can same manner. This will turn out to be your mini Dutch bucket system.
Now poke1/4" hole into tote now add 1/4" hose through hole.and connect to T connecter from coffee cans. Now this will drain from cans into tote. do this twice to make a 4 bucket system. or figure out a system of having them all drain in 1 line.
try leak tests now before running whole system or moving on. Use hot glue if needed. I never did
3 - Cut 4" or 6" holes into coffee can lids. depends on your preference of size. Use 3" if want.
Your net pots should fit tight and snug into lids and centered. snap on top of cans. now this is double bucket system. Easy to replace plants and clean as desired. place lid onto tote and place coffee cans on top of lid.
- I had thought of cutting.holes.through lid so buckets sit in lid and drain into tote.
This eliminates the drainage lines.
I like the idea of how it looks cool with all of the water/drainage lines and you add how ever many buckets you can manage within reasons.
4 - Setting up pumps and water emitting lines.
screw fitting onto pump to accommodate 1ft of 1/2" water line. cap off end of 1/2" line
push 4 - 1/4"drip emitters into 1/2" line and add 2 ft 1/4" lines onto emmitters (x4. )
poke 4 - 1/4"holes. through tote and run lines through holes. and up to net pots. all Holes for water/drainage lines should be about 2" to 3" below lid of tote. cut a slot into lid of tote to accommodate for power cord on pump or drill large holes for plug to fit through.
add air stone into tote and hook up to air pump ( keep air pump above water level at all times) that's pretty much it. It is fairly easy to set up, easy to run, take down, clean and change plants. Use whatever growing medium u prefer but if on a budget use Styrofoam I used an old seat cushion sterilized with boiling water and voila. u can use bit and pieces
cut up or cut circles to fit top of pots and use as aeroponics setup. try to set cans up any way you think will work. DWC, AEROPONICS, HYDROPONICS, DRIP LINES ETC. I belive that thus system would work to on a drain to waste system with soil or soil less medium. provided you add a filter in bottom of coffee cans so particles of dirt and perlite don't clog drainage . Also a good addition for this project is to purchase a ball valve for 1/2" line and run a drain line out for your tote to drain water for easier times in cleaning ;) .
for plastic leaching into soils I'm not sure... but I'm not too worried about it. plants want nutrients not plastics. I am growing ornamentel house plants, herbs, and medicinal cannabis in this system and all plants are loving it.
  • Water Contest
    Water Contest
  • Backpack Challenge
    Backpack Challenge
  • Stick It! Contest
    Stick It! Contest
5 Discussions
PamG10
2 years ago
Bubble Jugs are cheaper and easier to operate. Good luck and keep a close eye on Ph and nutrient levels.
Hey thanks for the tip I've looked it up and will be doing those as well. Cheers
Yes me too, and have wanted to for years. Now I researched some info and adapted to it. This is my first instruct able and I'm still working with it enjoying it so far. Easier than I ever thought to set up and build. I forgot to mention that I've used two lids one is upside down helps keep cans level and draining properly. Plants are still alive and not wilting, but in state of shock from the transplant from soil to Styrofoam didn't help I'm sure. I'm sure they will survive... up and running day 2 now.
Day 4 plants still alive signs of stress but starting to take roots. Roots Looking white :)
Almost had floods. Recommend drain holes in coffee cans 1/4 to 1/3 up from bottom of can. I also eliminated the drain lines and T connecter and let bucket drain through the lid into tote. instead seams more reliable this way. Next time I will use a bigger drainage line from buckets to tote. As the T connecter ended up plugging up twice on me. I do need a filter on pump too maybe??? Not sure yet lol. I am using general organics in reservoir and think I do have some peat floating around from roots of plants. Should wash more thorough next time.
