Homemade Joule Thief Circuit Board
Published
Introduction: Homemade Joule Thief Circuit Board
All Step by Step Movies on Youtube - Click here to See all
Joule Thief? It’s a little wisp of a circuit that allows you to drive a blue or white LED from a low voltage. Normally, if you want to light up a blue or white LED you need to provide it with 3 – 3.5 V, like from a 3 V lithium coin cell. But a 1.5 V battery like a AA cell simply will not work. But using the Joule Thief, it works like a charm. Not only does it work with a brand new battery, but it works until the battery is nearly dead– down to 0.3 V
Step 1: Tools and Parts
Soldering Iron Solder
White LED
NPN Transistor
1k Resistor (Brown-Black-Red)
Step 2: Complette
In the circuit diagram for the Joule Thief, the common point of the toroid is the connection at the top of the hand-wound ferrite toroid, in the upper right of the diagram. This goes to the positive end of the battery. The other two wires from the toroid go to the resistor and to the intersection of the transistor with the LED
All Step here On Youtube - See and do it now
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    This looks like a great project!
    If you wanted to, you can actually embed the video right here in your project. Just a thought! :)
