Homemade Kitchen Cabinet Door Organizers
14,304
523
6
Published
Introduction: Homemade Kitchen Cabinet Door Organizers
About: Just a normal guy trying to make it in life .Good paying job but mindless sometimes .I enjoy making things in my garage to keep my mind going .. Its fun making something new but its more fun taking somethi...
Here is a easy way to save space in your kitchen cabinets.Its a great way to organize.
Step 1: Side Boards
Step 1 *  I purchased  a 1x6x8 pine board .  I measured and cut two  pieces 20 inches long.
Step 2 *  Measured and ripped both boards 4 inches wide on the table saw.
Step 2: Marking for Dowel Holes
Step 1 * Measure up from the bottom of both boards 5/8  of a inch .
Step 2 * measure in  3/4 of a inch  on each side  of the board .
Step 3 * Next measure up 9 1/4  inches from the bottom. Measure  in 3/4 of a inch  from each side of the board . These marks  are for the two dowels for the second tier.
Step 4* measure up 5 inches from the bottom of the board  and 5/8 in from from one edge of the board.
Step 5 *  Next measure up from the bottom of the board  14 inches and then 3/4  of a inch in from the  edge.
Step 3: Drilling Dowel Pin Holes
Step 1*  I  used  a 3/8  spade bit to drill the 12 holes in the boards
Step2* I used a round over bit in my router to round both edges of the boards.
Step 4: Installing the Dowels
Step1*  I used  3/8 dowels for the job.
Step 2*  measure  and cut  6 pieces  14 inches long.
 Step 3* Fit the dowels in each hole of one board . Make sure there flush with the outside edge.
Step 4* Pre drill a hole on the outside edge  of each hole with a 1/8 inch drill bit.
Step 5* Use # 6 finish hails to hold the dowels in place.
Step 5: Installing to the Door
Step 1 *  I used four 1 inch by 1 inch  angle brackets .
Step2* I measured down 4 inches from the top and 4 inches up from the bottom.
Step3* I installed the brackets flush to the outside edge .
 Step 4 *  finished........
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
6 Comments
This seems like such a simple and effective idea to make the most of your cupboard space! Hope to see more similar ideas like this to help maximise my kitchen space!
This is a great idea, thank you for sharing! Voted! :D
It all looks so simple when you do it. :)
