Introduction: Homemade Kitchen Cabinet Door Organizers
Here is a easy way to save space in your kitchen cabinets.Its a great way to organize.
Step 1: Side Boards
Step 1 * I purchased a 1x6x8 pine board . I measured and cut two pieces 20 inches long.
Step 2 * Measured and ripped both boards 4 inches wide on the table saw.
Step 2: Marking for Dowel Holes
Step 1 * Measure up from the bottom of both boards 5/8 of a inch .
Step 2 * measure in 3/4 of a inch on each side of the board .
Step 3 * Next measure up 9 1/4 inches from the bottom. Measure in 3/4 of a inch from each side of the board . These marks are for the two dowels for the second tier.
Step 4* measure up 5 inches from the bottom of the board and 5/8 in from from one edge of the board.
Step 5 * Next measure up from the bottom of the board 14 inches and then 3/4 of a inch in from the edge.
Step 3: Drilling Dowel Pin Holes
Step 1* I used a 3/8 spade bit to drill the 12 holes in the boards
Step2* I used a round over bit in my router to round both edges of the boards.
Step 4: Installing the Dowels
Step1* I used 3/8 dowels for the job.
Step 2* measure and cut 6 pieces 14 inches long.
Step 3* Fit the dowels in each hole of one board . Make sure there flush with the outside edge.
Step 4* Pre drill a hole on the outside edge of each hole with a 1/8 inch drill bit.
Step 5* Use # 6 finish hails to hold the dowels in place.
Step 5: Installing to the Door
Step 1 * I used four 1 inch by 1 inch angle brackets .
Step2* I measured down 4 inches from the top and 4 inches up from the bottom.
Step3* I installed the brackets flush to the outside edge .
Step 4 * finished........
