Homemade Laptop Table for Bed
1,243
16
Posted
Introduction: Homemade Laptop Table for Bed
This is a laptop table for the bed, I like to watch movies before falling asleep, but keeping a laptop on your knees is uncomfortable. That's why I built this laptop table. In addition, I use this table to put down the phone for a night battery charge. I also equiped this table with a night lamp that can be easily switched on and off with your foot. The shelf from the table is mounted on hinges, so I can easily change the angle of inclination.
This article can also see here:
Homemade laptop table for bed
Step 1: Components and Tools
Step 2: Measuring and Cutting
All elements I measured and trimmed accordingly, as shown above.
Step 3: Welding Bracket
This bracket I welded with two square pipes and two flat bars.
Step 4: Putting Everything Together
At first I mounted my bracket to two wooden beams. Then I connected OSB boards with wooden beams using metal angles. In the next step I made a wooden frame, to which I installed a comb limiter. Using the hinges, I connected two wooden beams with a shelf. It is easy to change the angle of the slope of the shelf. I mounted this wooden beam to protect against slipping. Protection against slipping from the shelf. I glued the power strip with two-sided adhesive tape. In addition to the shelf I attached a cork from wine. This allowed me to put my phone under the power supply. I also mounted a night lamp that can be easily switched on and off with your leg. Switched on and off night lamp.
Step 5: The End
Finally I put my new laptop shelf between the bed and the wall.
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
