Homemade Laser Robotic Drawing Plotter Draw DIY X Y Axis Slide Linear Frame
441
12
Posted
Introduction: Homemade Laser Robotic Drawing Plotter Draw DIY X Y Axis Slide Linear Frame
Free stl files for 3D Printer available here:
Hardware:
EleksMakerĀ® ManaSE 2 Axis Stepper Motor Driver Controller Board For DIY Laser Engraver
3 Nema 17 stepper motor
1 pcs 2500mw 405NM Focusing Blue Purple Laser Module Engraving
3 Nema 17 Stepper Motor 17HS8401,1.8A,4.8kg.cm Holding Torque,5mm Diameter Shaft
3 pcs GT2-6mm open timing belt width 6mm 400 mm
3 pcs GT2 Timing Pulley 20 teeth Alumium Material Inner Diameter 5mm for 6mm width Belt
4 pcs 2020 Aluminum Extrusion Profile European Standard 300 mm
1 pcs 2020 Aluminum Extrusion Profile European Standard 290 mm
3 pcs IKO LWL 15 Linear Rail Length 280mm
Step 1: DIY X Y Axis Slide Linear Frame
2 Nema 17 Stepper Motor 17HS8401,1.8A,4.8kg.cm Holding Torque,5mm Diameter Shaft
2 pcs GT2-6mm open timing belt width 6mm 400 mm
2 pcs GT2 Timing Pulley 20 teeth Alumium Material Inner Diameter 5mm for 6mm width Belt
Step 2: DIY X Y Axis Slide Linear Frame
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Gluten Free Challenge
Are the .stl files available anywhere?
