A. Save money
B. Be ecologically phosphate free
If you learn from my mistakes your results will surpass mine in both respects, I am sure.In addition to my clothes coming out "so fresh and so clean, clean" it was a very satisfying and aesthetic making process!
Step 1: Gather Materials
Food processor
1 bar laundry soap like Fels Naptha or Zote, or Ivory - Zote can be found in hispanic grocery stores
1 Box Borax - found in the laundry aisle
1 box Washing Soda or Oxi Clean, orBaking soda - (Washing Soda AKA soda ash AKA sodium carbonate available in some grocery stores made by Arm and Hammer or you may find it art supply stores in the dyeing section)
OPTIONAL- essential oil of your choice, I didnt do it but I think tea tree might be nice.
Some recipe considerations, there are many variations to be found online but I based mine on this here http://www.thegreenguide.org/article/diy/household
Powdered Laundry Detergent
# 1 Cup Grated Fels Naptha Soap
# 1/2 Cup Washing Soda
# 1/2 Cup Borax
# For light load, use 1 Tablespoon. For heavy or heavily soiled load, use 2 Tablespoons.
I adjusted for the fact that Zote is at least twice as big as a Fels Naptha bar, and personally if I'm going to make a mess I'd rather double or triple the recipe which still easily fit in the food processor, also I used baking soda AND oxi-clean instead of the washing soda, the reason being that I could not find the washing soda, and Oxi-clean is essentially the same thing but with added peroxide* which does add a mild bleaching action, should be "color safe" though. It is also my understanding that baking soda is similar to washing soda but half as alkaline, so using baking soda will give you a gentler blend.
*note don't try and make the liquid recipe behind the link with "oxi clean" because the peroxide will make the whole mess foam, that was what I originally tried -- and ended up with useless semi solid foamy spooge.
Step 2: Grate your Bar
Step 3: Add other ingredients
Step 4: Conclusion
But not sure if ....
A. that Zote is phosphate free, and (EDIT: someone commented that phospahates have been illegalized anyway, havent fact checked that though)
B. the purchase of the oxy clean sure drove my cost up, next time I will find the Washing soda.
borax 3.59
baking soda .75
Zote .75
oxyclean 5.00
= 10.09
But since one or two little scoops are enough I estimate about 75 washes? so that comes out to .12 a wash, I guess even using oxi clean it's not so bad.
Visit Our Store »
Go Pro Today »
Heres a way to save 99% of any washing detergent costs...
For last 14 years my family has used a laundry "donut" in washing machine.
It is a hollow plastic donut about 4 inches diameter. With a coloured liquid inside.
Cost about 40 bucks 14 years ago.
Goes in washer and swishes around.
As a result , My clothes have NO detergents embedded in them.
Have not needed any washing detergent at all for 14 years as a result!
Just think of that $ saving..
Am not a mechanic etc s no ultra greasy clothes . Just normal use clothes.
Anything like that can be presoaked if need be in a bucket.
As an experiment.....
Try washing your normal clothes with no detergent in machine. It will take about 3 washes to remove all the residue!
I can assure worried people that yes my clothes are clean. they last longer and have no chemical soap smells. Sunlight does a great job.
I was a skeptic at first, 14 years later I know better! And am richer as a result...
We wear normal make clothes just like anyone else, by the way..
Have a nice day from Australia
not sure if my donut is still around..Bought in Australia ...
Ceramic washing balls are an alternative type item
eg
http://www.superwashball.com/store/index.php/default/super-wash-ball.html
Or find a "hippy" alternate lifestyle. mag . They often have them.
I have not used one but around and serve similar purpose no doubt.
Have seen comments that these items are a"con" and do either nothing or make washing worse.
I was a skeptic myself.
Like my post says..
My wife and I have used our donut for 10 + years.
She is no mug. Has a masters degree in museum conservation! so not easily fooled.And knows about fabrics etc.
More the con is overpriced overadvertised ove scented laundry powders!
Like I said , as a test wash your normal clothes with no detergent. See how much detergent residue comes out of washing machine for several cycles!
good luck.
I have no interest in the product other than how many hundreds of dollars it has saved us!
The over frothy scented wash powders are not user friendly.
We bought the donut as a test and just leave in washing machine .
If nothing else it swishes around the dirt etc and keeps it moving in wash.
Every so often we run some vinegar throughwashing machine to freshen it up.
Anyway 14 years free of washing powder costs and weird scents is ok by us!
We like our sunshine scented clothes in Tasmania!
How to quickly tell if your water is hard - look inside your kitchen kettle. Is there any noticable build up of white calcium deposits on the heating element and surrounds? If so it's mild to severe hard water. The black bits are heat scorch marks common on the surfaces of stainless steel and plastic kettles and don't indicate hardness. The other method. How well does your bathroom soap lather up in your hands using just cold water? Little or none, water is hard. Good lather, water neutral or soft.
I haven't read all the comments so far and I apologize if someone has already posted this but a good source for sodium carbonate can be found in the pool supply section of most big stores as PH booster check the label that is is indeed sodium carbonate. The crystals (or flakes) are smaller than washing soda so it may be the same as the super washing soda. I use this all the time in my laundry and it is a wonderful addition for getting clothes cleaner with less detergent.
again good work on your project.
Dan
about 0.85c/bar 500grams
Homemade Liquid Laundry Soap- Front or top load machine- best value
4 Cups - hot tap water
1 Fels-Naptha soap bar
1 Cup - Arm & Hammer Super Washing Soda*
½ Cup Borax
- Grate bar of soap and add to saucepan with water. Stir continually over medium-low heat until soap dissolves and is melted.
-Fill a 5 gallon bucket half full of hot tap water. Add melted soap, washing soda and Borax. Stir well until all powder is dissolved. Fill bucket to top with more hot water. Stir, cover and let sit overnight to thicken.
-Stir and fill a used, clean, laundry soap dispenser half full with soap and then fill rest of way with water. Shake before each use. (will gel)
-Optional: You can add 10-15 drops of essential oil per 2 gallons. Add once soap has cooled. Ideas: lavender, rosemary, tea tree oil.
-Yield: Liquid soap recipe makes 10 gallons.
-Top Load Machine- 5/8 Cup per load (Approx. 180 loads)
-Front Load Machines- ¼ Cup per load (Approx. 640 loads)
*Arm & Hammer "Super Washing Soda" - in some stores or may be purchased online here (at Meijer.com). Baking Soda will not work, nor will Arm & Hammer Detergent - It must be sodium carbonate!!
Powdered Laundry Detergent - Top load machine
½ Cup Borax
-Grate soap or break into pieces and process in a food processor until powdered. Mix all ingredients. For light load, use 1 Tablespoon. For heavy or heavily soiled load, use 2 Tablespoons. Yields: 3 Cups detergent. (Approx. 40 loads)
TIPS FOR LAUNDRY SOAP: We use Fels-Naptha bar soap in the homemade soap recipes, but you can use Ivory, Sunlight, Kirk's Hardwater Castile or Zote bars. Don't use heavily perfumed soaps. We buy Fels-Naptha by the case from our local grocer or online. Washing Soda and Borax can often be found on the laundry or cleaning aisle. Recipe cost approx. $2 per batch.
Inexpensive Fabric Softener Recipes
Recipe #1
1 Cup White Vinegar
Add vinegar to rinse cycle. Works great. Removes residue and odors. Also helps to keep washing machine and hoses fresh and clean too.
Recipe #2
1 Container of Name Brand Fabric Softener
4 Inexpensive sponges, cut in half
Pour entire container of softener into a 5 gallon bucket. Fill empty softener container with water twice. (2 parts water to 1 part softener) Add sponges to softener/water mixture. When ready to use wring out extra mixture from one sponge and add to the dryer as you would a dryer sheet.
I have used Tea Tree oil in shampoo, lotion, makes sense it would work in soaps too. It smells very close to eucalyptus, and I put it in my humidifier too. It should be used in small quantities no matter where you use it, especially internal. That's why it's just on the toothpicks, it's just that strong.
1/3 cup grated soap (I used the sunlight bar soap)
melted in a sauce pan with 6 cups of water, When melted add in
1/2 cup of Washing soda &
1/2 cup borax powder
Stirred until melted.
Then put 4 cups of hot water in large pail, added the soap mixture and stirred. then added 22 cups of water which is suppose to equal 1 gallon + 6 cups of water stirred and let sit for 24 hours and it is suppose to gel.
I had it covered for a while then took the cover off, stirred it now I have the cover on it again and it still hasn't gelled?
What did I do wrong?
It is almost 48 hours now and is still liquid. IT also doesn't bubble when I put it in the wash machine since i don't have any other laundry soap i tried it any way.
Thanks to anyone who can help me out on what to do to make this gel.
Just noticed that the recipe you are using recommends much more water than the recipe I use.
I use 1/2 cup of each of the ingredients you use, with the exception that I use a little more grated soap and I use Linda Laundry soap instead of Sunlight soap. I also use only 16 cups of water in total.
So perhaps the reason why your mixture isn't gelling is because the recipe calls for a bit too much water......?
As for sudzing, my recipe doesn't create bubbles, but it does wash well.
Best wishes from http://youcanknowanything.blogspot.com/
This lack of sudsing also makes it safe for He machines.
http://grannyinanutshell.blogspot.com/search/label/homemade%20laundry%20soap
And it doesn't gel.. just kind of looks like egg drop soup. You don't want the bubbles on top of the water, they need to be down in it to do any good. :)
Anyway, I use this recipe for my hardwater laundry. I use hot or warm water for the washing machine so that there won't be residueon the clothing.
1/2 cup Borax
1/2 cup Arm and Hammer Super Washing Soda
1/2 cup grated Linda Laundry soap.
16 cups of tap water.
It is hard to locate soap bars like Fels Naptha or Octagon soap in my region of Canada, so I found the Linda Laundry soap bars to work fine. The mixture thickens up well. I use an electric hand mixer to smooth out any lumps and to make it nice and frothy.
As to where to buy the ingredients, here is where I found them in Ontario, canada:
Borax I bought for about 5 bucks at Home Hardware.
Arm and Hammer Super Washing Soda I bought at the Real Canadian Wholesale club for under 6 bucks.
The Linda Laundry soap bars I found at No Frills for $1.49 each.
Blessings from http://youcanknowanything.blogspot.com/
