Homemade Metal Lathe DIY Spindle Headstock by Drill Chucks
Published
Introduction: Homemade Metal Lathe DIY Spindle Headstock by Drill Chucks
Homemade Metal Lathe DIY Spindle by Drill Chucks
A lathe is a piece of equipment used for shaping wood or other material. It consists of a base, which can be mounted on a bench or work table, and then, on either side, the headstock and the tailstock. The headstock has the spindle bearing which control the spindle, the part of the lathe which turns. The tailstock helps balance the spinning headstock, and features a stationary hollow horizontal access for a steel cylinder, which can be adjusted for accepting or stabilizing different sized tools and drill bits to cut the spinning material.
Spindle Headstock very easy for DIY with old hand drill, aluminium, bearing, and few time....
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
