Homemade Mini CNC Milling Router Mill DIY Z Collet ER11 Axis Slide Stage Frame Aluminium
Published
Introduction: Homemade Mini CNC Milling Router Mill DIY Z Collet ER11 Axis Slide Stage Frame Aluminium
Homemade Mini CNC Milling Router Mill DIY Z Axis Slide Stage Frame Aluminium
Materials for Z Axis DIY 100 mm travel
Collet ER11 Spinde DIY
1 pcs Aluminium 200 mm x 82 mm x 10 mm
2 pcs Aluminium 42 mm x 82 mm x 10 mm
1 pcs Aluminium 90 mm x 82 mm x 8 mm
1 pcs 150 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 150 mm with Copper Nut
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler
2 pcs 12 mm 12 x 200 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
