Homemade Mini CNC PCB Milling Router Mill DIY X Stage Frame Slide Aluminium Alloy
Published
Introduction: Homemade Mini CNC PCB Milling Router Mill DIY X Stage Frame Slide Aluminium Alloy
Materials:
2 pcs Aluminium Alloy 420 mm x 42 mm x 12 mm
2 pcs Aluminium Alloy 290 mm x 42 mm x 12 mm
1 pcs Aluminium 200 mm x 200 mm x 6 mm for top
1 pcs 340 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 340mm with Copper Nut
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer and cnc router mini motor step robotic
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler Encoders Engraving Machine Coupling
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
2 pcs 12 mm 12 x 400 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
4 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Planter Challenge
      Planter Challenge
