Homemade Mini Circular Table DIY Cutting PCB With Collet ER11 and Motor Drill
Published
Introduction: Homemade Mini Circular Table DIY Cutting PCB With Collet ER11 and Motor Drill
Homemade Mini Circular Table DIY Cutting PCB with Collet ER11 and Motor Drill
Materials:
1 pcs aluminium alloy 220 mm x 220 mm x 6 mm
1 pcs aluminium alloy 250 mm x 100 mm x 12 mm
1 pcs aluminium alloy 100 mm x 80 mm x 16 mm
1 Pcs Stepper Motor Mounting L Bracket Mount Step Stepping
1 pcs Motor 50 watt 11.1 volt DC take from old hand drill
2 pcs Deep groove ball bearing,bearing steel 6 mm X 15 mm X 7 mm
2 pcs Linear motion ball slide units block bearings SC8UU Bore size 8 mm
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 5 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
