Introduction: Homemade Mini Circular Table Drill Home Built Jig Saw DIY Cutting PCB Wood Machine CNC
Materials:
1 pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
1 pcs Aluminium 120 mm x 250 mm x 16 mm for bed
1 pcs Aluminium 150 mm x 150 mm x 6 mm for top
1 pcs Aluminium 40 mm x 150 mm x 20 mm 1 pcs Hand Drill nice work
1 pcs Special round steel pipes 25 mm x 60 mm
1 pcs Special round steel pipes 8 mm x 100 mm 2 pcs 19 mm x 8 mm x 8 mm Miniature Ball Bearings
1 pcs SK 25 linear shaft support 25mm Linear Rail Shaft Support XYZ Table CNC SHF Series Rail Shaft
More Homemade Mini Circular Table Home Built Jig Saw DIY Cutting PCB Machine here:
