Homemade Mini Circular Table Home Built Jig Saw DIY Wood Cutting PCB Machine Spindle Headstock Chuck
Published
Introduction: Homemade Mini Circular Table Home Built Jig Saw DIY Wood Cutting PCB Machine Spindle Headstock Chuck
Homemade Spindle here:
Materials:
1 pcs Aluminium 150 mm x 150 mm x 6 mm
1 pcs Aluminium 145 mm x 145 mm x 12 mm
1 pcs Aluminium 100 mm x 50 mm x 50 mm make hole 42 mm for motor
2 pcs SZS Wholesale FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
1 pcs motor 50 watt take from old hand drill 1 pcs Special round steel pipes 8 mm x 10 mm 1
pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
More Homemade Mini Circular Table Home Built Jig Saw DIY Cutting PCB Machine here:
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
