Homemade Mini Circular Table Home Built Jig Saw DIY Wood Cutting PCB Machine Spindle Drill Aluminium
Published
Introduction: Homemade Mini Circular Table Home Built Jig Saw DIY Wood Cutting PCB Machine Spindle Drill Aluminium
Materials:
1 pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
1 pcs Aluminium 200 mm x 200 mm x 6 mm for top
1 pcs Aluminium 60 mm x 60 mm x 55 mm make hole 42 mm for motor
4 pcs Aluminium 20 mm x 20 mm x 70 mm for foot
1 pcs Motor Hand Drill nice work
1 pcs Special round steel pipes 25 mm x 60 mm
1 pcs Special round steel pipes 8 mm x 100 mm
2 pcs 19 mm x 8 mm x 8 mm Miniature Ball Bearings
More Homemade Scara Robot Arm DIY Robotic Frame Projects Laser 3D Printer Draw here:
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    And what happens when you solder the wire to the motor, is the blade going to cut it.
