Introduction: Homemade Mini Circular Table Home Built Jig Saw DIY Wood Cutting Machine Spindle Drill Collet ER11
Materials:
1 pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
1 pcs motor 50 watt take from old hand drill
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs Special round steel pipes 8 mm x 90 mm
1 pcs Aluminium 70 mm x 90 mm x 35 mm make hole 42 mm
2 pcs SZS Wholesale FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
About This Instructable
1,672views
26favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
