Homemade Mini Circular Table Jig Saw DIY Spindle Tailstock Slide CNC Router Wood Cutting PCB Aluminium Alloy
Published
Introduction: Homemade Mini Circular Table Jig Saw DIY Spindle Tailstock Slide CNC Router Wood Cutting PCB Aluminium Alloy
1 pcs Aluminium 100 mm x 50 mm x 50 mm make hole 42 mm for motor
1 pcs Special round steel pipes 25 mm x 40 mm
1 pcs Special round steel pipes 8 mm x 60 mm
1 pcs motor 50 watt take from old hand drill 1 pcs Special round steel pipes 8 mm x 10 mm
1 pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
