Homemade Mini Circular Table Jig Saw DIY Spindle Tailstock Slide CNC Router Wood Cutting PCB Headstock Chuck
Published
Introduction: Homemade Mini Circular Table Jig Saw DIY Spindle Tailstock Slide CNC Router Wood Cutting PCB Headstock Chuck
1 pcs Aluminium 100 mm x 50 mm x 50 mm make hole 42 mm for motor
2 pcs SZS Wholesale FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
1 pcs motor 50 watt take from old hand drill
1 pcs Special round steel pipes 8 mm x 10 mm
1 pcs 4" saw blades for wood plastic cutting 100mm 20 mm 75 teeth
1 pcs Suitable for 10mm shaft diameter Motor cut and polished connecting rod can be equipped with 16MM \ 20MM hole saw
More Homemade Mini Circular Table Home Built Jig Saw DIY Cutting PCB Machine here:
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
