3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Mini Coaxial Airgun
Well this is my instructable for my coaxial airgun that I put together.
It costs about $15 to construct, and is very fun to mess around with.
It shoots at roughly 600fps+ at 120psi with a .12gram airsoft bb and the excact specifications of the airgun made in this instructable.
And I must state that ***IT IS NOT MY FAULT IF YOU OR OTHERS ARE HURT OR KILLED AS A RESULT OF THIS AIRGUN***
And a couple tips (pretty much follow them or you will die,no joke)
*Never pressurize it over 140psi, even though it says rated to 480psi on the side.
*Never look down the barrel, even when you dont think it is loaded or pressurized
*Never aim at anything you do not intend to destroy
*Do not use this in an airsoft war, this is meant to just be something to mess around with. It will penetrated human flesh.
*Give the pvc cement and epoxy a full 24 hours to dry, no less.
*Have fun
Make sure you understand all those tips before going to next page.
And if you dont understand how a piston valve works then this is a helpful link.
Step 1Getting Parts
Getting Parts
Well go to some hardware store and aquire all thse parts
1x 1/4in ball valve(metal)
2x 3/4in to 1/2in bushings(metal)
2x 3/4in female adapter(pvc)
1x length of 3/4in pipe of the desired size(pvc)
1x 1/2in copper cap
1x 6mm brass or aluminum tube of the desired length(might not be avaiable at your hardware store, try a hobby shop)
2x 1/2in to 1/4in bushing(metal)
1x 1/4in NPT schrader valve
3x 1/4in close nipples(prefferabley brass over steel)
1x double syringe container of epoxy
whatever tape strikes your fancy
bike inner tube
And some tools that you most likely have but if you dont you need to get them.
Scissors
Clamp
Adjustable wrench
Pipe wrench
A vice is helpful but not nesessary
A nail(or similar)
And that is it
If you dont have some of tools the project will be a lot more pricey.
29 comments
Aug 17, 2011. 12:11 AMSharky44401 says:
awesome instructable, im gonna try making it this weekend.
Jun 29, 2011. 8:51 AM$0m3_0n3 says:
Where did you get the barrel? Is it the one from a walmart "shotgun"?
Jul 20, 2011. 8:32 AMGreat Wight Ninja says:
I found a workable tube at Hobby Hut. Any hobby shop is more likely to have the right size tube than a hardware store would be. Mine turned out to be an American standards measurement for diameter instead of 6mm, but it still works quite well since you don't need perfect fitting. Just bring a BB with you when you go and see what the smallest size is the BB will fit through.
Aug 30, 2010. 9:41 PMGreat Wight Ninja says:
The video cited for applying the epoxy is no longer on youtube and some pictures or diagrams of the piston in and out of the chamber would be helpful.
Apr 29, 2010. 8:38 PMEVIL Ninjection says:
ive been shot by a 650fps full auto airsoft gun and now i have scars so dont shoot this at your friends cuz they will be PISSED! i kno u already said that up above but i just dont want anyone hurt or mad.
Feb 1, 2010. 1:34 PMHades di Angelo says:
Message me when you figure out where you can get pvc
Mar 12, 2010. 1:21 AMlemminggenocide says:
hardware store, warehouse
May 29, 2008. 4:42 PMjoejoerowley says:
Very Cool! Great Instructable! Looks LIke a great gun. Now just make a hopper and loader for it and strap a CO2 tank to it and you have the most bad ass gun ever! Well done!
Dec 19, 2008. 3:33 PMbob the builder #1 says:
learn what a coaxial is, then you'll understand why you can't add a hoppper
Jun 20, 2009. 7:50 PMAnarchistAsian says:
there's a way, it's just hard to do
Apr 30, 2009. 9:25 AMteapotking says:
doesn't coaxial just mean it moves in sync with another gun? for example if a tank had a machinegun mounted on the main turret just to one side of the barrel, that would be coaxial. i'm not seeing any turret here... nice gun though
Jun 15, 2009. 12:48 PMc.huchel says:
think like coaxial antenna wire. one around the outside of the other.... hence co-axial
Oct 18, 2008. 4:28 PMclemsonguy1125 says:
do you have to repump it every time you want to fire it
Jun 12, 2008. 1:35 PMbob the builder #1 says:
yes
Oct 3, 2008. 10:57 AMevanwehrer says:
This is really cool, when i make mine, I'm gonna use the air can from this instructable. And I may find an electric valve if I can find one wit the right size.
(Ill try to post pictures)
Sep 15, 2008. 2:28 PMthebluemartyr says:
why did you remove all of your videos??
Sep 22, 2008. 12:23 PMaerophyte says:
Can you please post a video shooting the airsoft ammo and then one shooting liquid (loaded after pressure us applied)? Thanks!
Sep 18, 2008. 2:51 PMhenrywfstone says:
from what i can tell this looks great! but i have no idea how to make it. NEED DIAGRAMS !!!!!!!! i REALLY REALLY want to make this! :P it would be perfect for my physics project (im designing body armour)
May 31, 2008. 7:34 PMMattrox says:
how does the firing system work im stumped
Jun 1, 2008. 1:45 PMMattrox says:
thanks
Jun 1, 2008. 10:22 PMMattrox says:
great work very helpfull 3.5 rating
May 31, 2008. 5:16 PMMattrox says:
awesome bigbob12345 but could you add some boxes naming the parts pleaz
May 31, 2008. 7:31 PMMattrox says:
cool looks great
May 30, 2008. 4:09 AMdrummonkey92 says:
nice one mate in the intro at the end of the list of things to 'pretty much follow or you will die' you said have fun...haha 'have fun or you will die' i like it!!
May 29, 2008. 8:34 PMSgt.Waffles says:
Sick as! Good on ya!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bigbob12345
