Homemade Mini Mill Drill DIY Table Drill Press
Published
Introduction: Homemade Mini Mill Drill DIY Table Drill Press
Specification:
Specifications
Compact design and portable. Be used for drilling, grinding on wood, metal and non-metal
The mini power tools designed for DIY enthusiasts and homeowners, and delivers cost-conscious pricing without compromising on quality. The range features machines for all of your DIY needs, With hand drills mini power tools, you can be sure you'll find just what you need for that special project.
Bench drill Features: Hand drills Rated power: 200 - 300 W voltage frequency 230V Max. drilling capacity: 3.2mm (steel materials), 6mm (non-metallic), 5mm (copper, aluminum materials) Spindle travel: 100 mm Table size: 250 mm x 168mm
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
Material:
1 Linear Bearing Flange Type Linear Bushing Flange Type 25 mm
1 pcs 400 mm 25mm Shaft Long Hardened Rod Linear Motion Shafts
1 pcs 120 mm 20mm Shaft Long Hardened Rod Linear Motion Shafts
1 pcs SHF25 Size 25mm Linear Rail Shaft Support
1 pcs SHF25 Size 20mm Linear Rail Shaft Support
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    I wish you had made it before i bought the drill stand, man!
    i was searching the internet like crazy for something like this.
