Introduction: Homemade Mini Mill Router DIY XYZ Axis Slide CNC by Aluminium Alloy
Homemade Mini Mill Router DIY XYZ Axis Slide CNC by Aluminium Alloy 6061
Specification:
Spindle Ozito or Dremel Rotary hand tools ( Ozito Rotary tools 170 Watt 12000 rpm )
Z Axis Travel 250 mm
Y Axis Travel 100 mm
X Axis Tavel 150 mm
Bed make by Aluminium Alloy 12 mm x 150 mm x 300 mm
It is very nice work with Makita 3709:
Transparent plastic base for clear view of trimming edge
Rubberized soft grip providing comfort and control
Smooth and precision depth adjustment with rack and pinion mechanism
Power supply cord attached upright to the top of housing allowing easy grip and handling
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
More Step by Step Homemade Mini Lathe DIY Wood Milling CNC Router here:
About This Instructable
1,724views
48favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
