Homemade Mini Milling PCB Router Mill DIY X Stage Frame Axis Slide CNC Aluminium
Published
Introduction: Homemade Mini Milling PCB Router Mill DIY X Stage Frame Axis Slide CNC Aluminium
Homemade Mini Milling PCB Router Mill DIY X Stage Frame Axis Slide CNC Aluminium Alloy
Materials:
1 pcs Aluminium 150 mm x 350 mm x 12 mm for bed
1 pcs Aluminium 150 mm x 80 mm x 35 mm make 2 hole 28 mm and 1 hole 12 mm center
2 pcs rod shaft 20 mm x 220mm cnc linear rails CNC rod
1 pcs BK10 BF10 Set one pc of BK10 and one pc BF10 for SFU1205 Ball Screw End Support CNC
4 pcs LM8UU 20 mm Linear Bushing CNC Linear Bearings
4 pcs SK20 20 mm linear rail shaft SH8A for XYZ Table CNC machine
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
