Introduction: Homemade Mini Milling Router Mill DIY X Y Z Axis Slide Aluminium Stage Frame CNC for 3D Printer
Materials:
1 pcs Aluminium Alloy 200 mm x 80 mm x 9 mm
2 pcs Aluminium Alloy 80 mm x 42 mm x 12 mm
1 pcs Aluminium Alloy 110 mm x 80 mm x 6 mm
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler Encoders Engraving Machine Coupling
1 pcs 260 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 260mm with Copper Nut
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer and cnc router mini motor step robotic
2 pcs 12 mm 12 x 300 mm linear shaft 3d printer cylinder linear rail linear shaft axis cnc part
4 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
bcboy1956 (author)2016-10-21
Do you have any layout diagrams
About This Instructable
962views
11favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
