Introduction: Homemade Mini Milling Router Mill DIY XYZ Axis Slide CNC
More Homemade Mini Grinder Belt DIY Sanding Wheel Home Built Grinding Machine here:
2 pcs 20mm x 400 mm linear shaft Cylinder Liner Rail Linear Shaft Axis CNC
2 pcs SC20UU SCS8UU 20 mm Linear Motion Ball Bearing Slide Bushing Linear Shaft for CNC
1 pcs Ball Screw 1605 L 400mm 16mm Rolled ballscrew
1pc SFU1605 with 1pc 1605 Flange single ballnut for CNC
2 pcs aluminium alloy 122 mm x 40 mm x 20 mm for Hold Liner Rail Shaft Axis
1 pcs aluminium alloy 122 mm x 400 mm x 12 mm for bed
1 pcs aluminium alloy 160 mm x 160 mm x 12 mm on top
1 pcs aluminium alloy 60 mm x 12 mm for handwheels
About This Instructable
2,665views
21favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
