Homemade Mini Milling Router Mill DIY Z Axis Slide Aluminium Stage Frame CNC for 3D Printer
Published
Introduction: Homemade Mini Milling Router Mill DIY Z Axis Slide Aluminium Stage Frame CNC for 3D Printer
Materials:
Travel 250 mm long
1 pcs Aluminium 250 mm x 110 mm x 16 mm for bed
1 pcs Aluminium 90 mm x 90 mm x 8 mm
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
1 pcs THSL-300-8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 340mm with Copper Nut
2 pcs 12mm linear shaft L 400mm chrome plated linear motion guide rail round rod shaft for cnc parts 3d printer parts
1 pcs 8x10mm CNC Stepper Motor Shaft Coupler Flexible Coupling OD 25x30mm CNC parts
1 pcs Nema17 stepper motor 0.9 deg /48mm/ 78 Oz-in / 1.8A CNC stepper motor stepping motor
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
