Homemade Mini Milling Router Mill Machine DIY X Y Z Axis Slide Frame CNC
Published
Introduction: Homemade Mini Milling Router Mill Machine DIY X Y Z Axis Slide Frame CNC
What do you do when you want a milling machine but don’t have the room or the funds for the massive professional equipment needed to cut custom parts? I found myself with this dilemma, so I chose to scale down my purchase and invest in a manual mill that I could eventually convert to mini router do it by my hand
DIY X Axis Slide here:
Travel Z axis 200 mm. Travel X 105 mm long, Travel Y 250 mm long
X Y Axis Homemade here:
This machine to the right shows a Ozito or Dremel fitted into the holder of a spindle. Notice the wooden distance piece, it shows the difference in diameter.It is nice work are still sufficient for PCB or wood milling
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
