Homemade Mini PCB CNC Milling Router Mill DIY Spindle Collet ER11 Axis Slide Stage Frame Aluminium
Published
Introduction: Homemade Mini PCB CNC Milling Router Mill DIY Spindle Collet ER11 Axis Slide Stage Frame Aluminium
Homemade X Axis Slide here:
Homemade Y Axis Slide here:
Homemade Z Axis Slide hrer:
Materials for X Y Z Axis DIY
Collet ER11 Spinde DIY
2 pcs FL08 2 Bolt 8mm Bore Self-aligning Flange Ball Bearing
2 pcs Aluminium Alloy 290 mm x 42 mm x 12 mm
2 pcs Aluminium Alloy 420 mm x 42 mm x 12 mm
2 pcs Aluminium Alloy 300 mm x 42 mm x 12 mm
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
1 pcs 330 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm Length 300mm with Copper Nut
1 pcs 350 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm Length 300mm with Copper Nut
1 pcs 150 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm Length 300mm with Copper Nut
3 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer
3 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler
2 pcs 12 mm 12 x 400 mm linear shaft 3d printer cylinder linear rail linear shaft axis
2 pcs 12 mm 12 x 350 mm linear shaft 3d printer cylinder linear rail linear shaft axis
2 pcs 12 mm 12 x 200 mm linear shaft 3d printer cylinder linear rail linear shaft axis
8 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
