Homemade Mini Press Drill DIY Micro PCB Driller
1,297
39
Posted
Introduction: Homemade Mini Press Drill DIY Micro PCB Driller
Printed circuit board or PCB is one of the important things to assemble
More Homemade Mini Grinder Belt DIY Sanding Wheel Home Built Grinding Machine here:
an electronic circuit. It provides support to the components and makes electrical connection between the parts. In PCB assembling, the components are placed on one side of the Copper laminate passing their pins or leads to the other side through the holes. The pins/leads are then soldered to connect with the PCB tracks. Here explains the easiest method to make a homemade PCB for prototyping. It is very cheap and easy for do it,
Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
