Homemade Mini Press Drill PCB Drilling DIY Collet ER11 Spindle Motor Extension
Published
Introduction: Homemade Mini Press Drill PCB Drilling DIY Collet ER11 Spindle Motor Extension
DIY Frame Bed here:
DIY Z Axis Slide CNC here:
Materials:
1 pcs motor 50 watt take from old hand drill
1 pcs aluminium alloy tube 45 mm x 10 mm 19 mm hole
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 8 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
2 pcs Aluminium 42 mm x 80 mm x 12 mm
1 pcs Aluminium 200 mm x 80 mm x 10 mm
1 pcs Aluminium 100 mm x 80 mm x 10 mm
2 pcs rod shaft 12 mm x 200 mm cnc linear rails CNC rod
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
Materials for bed
1 pcs Aluminium 280 mm x 110 mm x 16 mm for bed
1 pcs Special round steel pipes 300 mm x 45 mm with bed 90 mm x 10 mm
1 pcs Special round steel pipes bed 150 mm x 12 mm
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
