Homemade Mini Press Drill PCB Drilling DIY Collet ER11 Spindle Motor Extension
Published
Introduction: Homemade Mini Press Drill PCB Drilling DIY Collet ER11 Spindle Motor Extension
Materials:
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
2 pcs 12 mm 350 mm linear shaft Cylinder Liner Rail Linear Shaft axis cnc parts make gear 8 mm x 20 mm
1 pcs Aluminium 110 mm x 260 mm x 16 mm for bed
2 pcs Aluminium 80 mm x 80 mm x 12 mm
1 pcs Aluminium 35 mm x 150 mm x 8 mm make 3 hole 21 mm
1 pcs ER11 Motor Shaft Extension Rod Inner Hole 5 mm Optional Engraving Machine Clamping Collet Drill Sleeve Motor Extension
1 pcs motor 50 watt take from old hand drill
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
