Homemade Mini Wood PCB Milling Router Mill Frame DIY Collet ER11 X Y Z Stage Axis Slide CNC Aluminium Alloy
Published
Introduction: Homemade Mini Wood PCB Milling Router Mill Frame DIY Collet ER11 X Y Z Stage Axis Slide CNC Aluminium Alloy
Homemade X Axis Slide here:
Homemade Y Axis Slide here:
Homemade Z Axis Slide and Collet ER 11
Materials for Z Axis DIY 100 mm travel
Collet ER11 Spinde DIY 1 pcs Aluminium 200 mm x 82 mm x 10 mm
2 pcs Aluminium 42 mm x 82 mm x 10 mm 1 pcs Aluminium 90 mm x 82 mm x 8 mm
1 pcs 150 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 150 mm with Copper Nut
More Homemade mini Milling DIY X Y Z Slide CNC Drill Home Built Lathe Router Machine
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
