The recipe was based on Wikipedia's description of the history of plasticine - calcium carbonate, wax, petroleum and mineral oil.
The closest thing to calcium carbonate I have is a material to make fillers for tiles and concrete and also called hydrated lime - the stuff used to
make your own paint. Some recipes online recommend paraffin wax. Others say this will result in a crumbly mix. Also there are toxic fumes to consider when remelting paraffin wax. On the other hand beeswax is quite safe.
Calcium carbonate / calcium hydroxide powder is available at any hardware store.
Wear a dust mask and eye protection for safety when handling lime powder / sand - also during cooking is advisable. Fumes rise up when mixing calcium carbonate with water and begins to heat up and bubble when away from the stove. (Can damage the lungs and respiratory system if inhaled. I was coughing for weeks
("Lime is an alkaline substance and therefore, caustic. You need to wear gloves, long sleeves, and eye protection to avoid the possibility of lime burns." - Janine Bjornson (Green Home Natural Building Plaster)
Beeswax has the advantage of being remelted over and over, so I decided on experimenting with beeswax, that way I can constantly adjust my recipe until I'm happy with the texture. It has a pleasant fragrance as well.
So after a bit of mixing and adjusting - these were the final measurements to make a cup of cream-coloured plasticine.
(You need two old pots for melting everything - not to be used with food ever again)
Ingredients
1 A4 sheet 100% beeswax (70g-100g)
6 teaspoons mineral oil (baby oil)
optional - 1 tablespoon liquid paraffin
4 tablespoons petroleum jelly (vaseline)
2 tablespoons 100% coconut oil / linseed oil
3/4 cup limestone powder (calcium hydroxide ie. hydrated lime)
Purpose of ingredients
According to Wikipedia, the original recipe by
William Harbutt in 1897 is kept secret. But then lists the ingedients - "Plasticine is composed of calcium salts (principally calcium carbonate), petroleum jelly, and long-chain aliphatic acids (principally stearic acid)."
Beeswax is the binder and helps the dry and oily ingredients to stick together.
Coconut oil and
linseed oil both contain
8% stearic acid which helps the stay smooth in a way the mineral oils and petroleum oils do not
Liquid paraffin - preservative (
optional I do not personally use this in this recipe, because of the fumes, I believe beeswax to be safer)
Limestone powder gives bulk and body to clay
the other type of calcium carbonate is mixed with additives to make concrete or quicklime. i wouldn't use this, but used hydrated lime with stays malleable.
i found beeswax in the yellow pages and found a candle specialty shop which sold it so you could make your own beeswax candles.
it cost $20 for 10 sheets. the other place i found it on ebay for much less. as i said, its not necessarily cheaper to make it yourself, i made it for the fun of figuring out a working recipe. all the best!
You will be able to buy ball clay, feldspar, talc (magnesium carbonate) or calcium carbonate at a pottery store. It will be just as cheap or cheaper than caustic hydrated lime, and you can buy smaller quantities of it.
