Homemade Oil/Air Pump From Car Parts
22,683
55
9
Published
Introduction: Homemade Oil/Air Pump From Car Parts
About: Hi I'm Joe and welcome. I love to make Homemade Tools & More. I will have many things to put on the instructables for you to gander at. I hope you enjoy there educational value and have fun. Come se my h...
This is a homemade Oil/aAir pump I originally made for my foundry to pump oil but then later just use it to air up my tires around the house.
It work great and airs tires up very quick and it's not loud at all.
I just used an old ac pump off a truck I scrapped and a 3/4 motor I had also off an old furnace.
I had a metal box that was a printer switch box and some cheap parts from radio shack.
Now I used my homemade plasma cutter and cut the top off an old air compressor to use as a plateform but you can just use a 2x6 or 2x12 or just any kind of wood you want according to your scrape pile.
I welded to my base but if you use wood just use some bolts and washers.
Hope you enjoy and have fun.
Want to see more check my other instructable like homemade plasma cutter and Jacobs ladder.
Also my web site http://theplasmacutterman.com/.
Step 1: Instructions and Parts Needed
Here are your parts your gonna need and how I done it.
I also through in a couple of pictures I made before I built it to give me an idea of how I was to do it.
This is a Word document file with instructions and parts needed.
Step 2: 12 Volt Clutch Supply
Here is a pictorial schematic of how I wired the 12 volt Clutch supply.
You can get all these parts from radio shack or some old electronic equipment like an old treadmill.
Step 3: Finnish Up and View
Here you can use my pictures to see how I made my brackets.
They are very clear and easy to see how I made mine and you wont have any trouble.
I put all pictures and info in this step so you wont have to keep flipping back and fourth to study everything.
So it's all here for ya.
Have fun and enjoy.
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    9 Comments
    does the compressor got damaged for the lack of lubricant when it pumps air only ?
    no because I add a few drops every so often and its still kicking.
    It will always have a little inside unless you just run it for hours at a time, but for air tank, tires filling floating toys for pool its great.
    Also I use it to vacuum down car ac when it needs a charge.
    Nope, I only use it to fill air tank or tires.
    About once a year I let it suck up an oz or 2 just to keep it lubricated well.
    Without it being a closed system the internals stay lubricated for a long time.
    It looks like you used a York compressor like were used in lots of vehicles from the 70s to the 80s. They are known as the king of onboard air by the off road I g community that install them to air up tires. The large ones put out about 9cfm and they are alloild by a internal oil reservoir instead of being lubricated by the freon.
    I uses an ac compressor for a quick pop pump for a ram separator. Never thought to use it as an air pump.... Gonna see if it puts out enough to power an impact. Will let you know the outcome.
    I looking to build a vacuum pump for bagging. This looks an interesting a pretty cheap way of making one. How do car AC units keep lubricated?
    thanks and great instructable
    thanks guys yea it works great and fast too.
    I fabricate something like this 30 years ago and work perfect. Add a tank and check valve.
    Nice instructable, never thoughtof using a car's AC compressor.
    Cheers.
