Homemade Phone With Simple Electronic Circuits
Published
Introduction: Homemade Phone With Simple Electronic Circuits
About: I am a student of computer engineering
This project about communicating two people with basic electonic circuits. This is my Electronic circuits lesson's project. I want to make a video about it.
Description
Here is a simple but effective intercom circuit that is basedfully on transistors.The circuit is based on a three stage RC coupledamplifier. When the pushbutton S2 is pressed, the amplifier circuit wiredaround T1 & T2 becomes an astable multivibrator and starts producing theringing signals. These ringing signals will be amplified by the transistor T3to drive the speaker. When the push button S1 is released the circuit willbehave as an ordinary amplifier and you can talk to the other side through it. To construct a two way intercom, make two identical copies ofthe circuit given below and connect it according to the given connectiondiagram. The stand by current consumption of this circuit is around 20mA.
Step 1: Circuit Diagram With Parts List
Step 2: Connection Diagram
Step 3: Components
Notes
Assemble the circuit on a good quality PCB.Use 9V PP3 battery for powering the circuit.The Mic M1 can be condenser micro phone.Use push to ON type push button switch for S2.Use a slide switch for switch S1.S1 can be used to power the circuit.BEL 187 equivalent 2N2222, 2N4401, BC 548 You can replace BC548 with BC546, BC547, BC549, BC550
Step 4: How to Make
Drawing the circuit on the pcb
Step 5: Putting Components Into Pcb
Step 6: Soldering
Step 7: Cutting
Step 8: Putting Into the Box
Step 9: Soldering the Box
Step 10: Finish
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    2 Comments
    cool, then what's the difference with intercom?
    It is portable and there is no need to push the button to speak. You can speak without delay. The button give a voice like a ring. But the ring is not hearded in video. Because of background sound.
