3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Homemade Pomegranate Liqueur
Homemade pomegranate liqueur is surprisingly easy to make without any complex or out-of-the-ordinary tools and the results are both delicious and make perfect gifts for almost any occasion! All you need are a few simple ingredients, a few household kitchen utensils, and some time (it takes about a month and a half to properly age and cure).
Step 1Tools, Utensils, Ingredients, Etc.
I went with the simplest utensils, using everyday kitchen implements instead of some specialty items. I always try to make things work with what I have, and this recipe is simple enough that nothing too technical is necessary.
Ingredients:
- Pomegranates (roughly six, depending on their size)
- peel of 1 lemon (I prefer meyers)
- cinnamon stick
- 3 cups vodka
- 1 1/2 cups white sugar
- 3/4 cup water
Utensils:
- A large glass jar (I used a 3 litre jar)
- large plastic bowl
- paring knife
- vegetable peeler  (or knife)
- measuring cups (liquid and dry)
- metal strainer
- cheescloth
- saucepan
- small funnel
- glass bottles or storage containers for the final product
Notes on Utensils:
- Avoid plastic as much as possible when working with strong alcohol. Glass is always preferable.
- A food mill can be used for crushing pomegranate seeds, but certainly isn't necessary.Similarly, a tube siphon can be used to fill the bottles, but I find it just as easy to carefully use a measuring cup or ladle.
Notes on Ingredients:
- Pomegranate juice can be substituted if fresh pomegranates are unavailable, however Ive had better results using whole seed pods, as the seeds impart different characteristics to the liqueur and add more depth.
- I generally tend away from processed white sugar, however with this recipe - and most liqueurs - white sugar is the best way to go. unrefined, unprocessed sugars fail to yield as successful results.
- Other spices can be added as well, like cloves or star anise. My personal preference is to have more fruit flavored and less spiced liqueur (unless I go all out and make one heavily spiced). The spicing is up to you.
40 comments
Jan 9, 2012. 11:08 PMTheShabz says:
The process has begun. The only change I made is that I used ground cinnamon as I'd like to keep the spice taste throughout. I'll report back in about 6 weeks and let yall know how it turned out.
Thanks for the recipe.
Dec 29, 2011. 9:28 PMjacquiJB says:
Coming very late to the party, but I wanted to mention that you'll have a clearer end product and much less in the way of sediment if you don't "wring" the solids after straining (step 6).
Sounds very tasty, though. :)
Dec 9, 2011. 5:44 AMfpoorkazem says:
isn,t it dangerous if the white part of the pomegranate seeds , i mean the little ones inside them remain in the alcohol? i mean the blindness danger or some thing? although cinnamon stick, isn't it kinda wood? is it ok?
Apr 13, 2011. 10:27 AMBuckshott00 says:
great instructable. Where can you those small swing top bottles for cheap?
Dec 4, 2011. 3:33 PMpaganwonder says:
Thrift store, yard sales, local homebrew store. (my cheap might differ from your cheap)
Jan 31, 2011. 5:30 PMhelghast356 says:
Great instructable! Started a batch of this and it should be ready just in time for my 21st bday. I also chanced upon the exact same bottles used in this instructable at World Market for about 6 bucks a piece, if anyone is still searching.
Jan 17, 2011. 2:05 PMjase78 says:
you can buy pomegranits that have already been taken from the skin if your willing to pay the extra cash
Jan 11, 2011. 12:25 PMrpjphs says:
Where did you get the bottles pictured
Jan 7, 2011. 9:18 PMspark master says:
what is abv? I have never heard of that before.
thanks
Jan 8, 2011. 10:53 AMpuma b32 says:
"Alochol by volume" is the same as % or half the proof number.
80 proof = 40% or 40 a.b.v
Jan 10, 2011. 7:40 PMspark master says:
AHA,
I never have seen the abbreviation, I understand the concept though. Proof was th epoint at which alcohol if exposed to a flame ignites. The booze had to PROVE it was strong enough! goes back to jolly old drunk England I believe. In history class at one point the taverns had a sign that read drunk for half a penny dead drunk for a penny. I believe that was in the 1600's and taverns were every block or so.
thanks
Jan 6, 2011. 12:09 PMsoljoe says:
Great instructions. Where can i buy the bottles?
Jan 8, 2011. 3:45 PMthepelton says:
Bottles may also be purchased from www.sciplus.com
Jan 8, 2011. 3:43 PMthepelton says:
I read that the papery walls inside the seedpod are not harmful, and if ground up in a juice machine may acutally contribute to the healthful contents.
Jan 6, 2011. 8:27 PMevilangelgirl says:
very nice and clear instructions. I have made lots of these infused flavor liqueurs, and I agree with you that it's better to just eat the strawberries. It took literally two years for one of mine to mellow out enough to be drinkable. Lesson learned: choose quality over price. I also use corn sugar to make my simple syrup and give the liquid one last straining through a coffee filter in my funnel as I bottle it. Helps get rid of that last bit of sediment.
Jan 6, 2011. 10:43 AMjoaopeixe says:
there is another way to take the pods from the white stuff. After you cut in half, put the cut half in your left hand and gently strike the oposite site with a spoon. You can use a napkin to avoid any errant juice. You will be amazed how easy it is.
Jan 6, 2011. 8:13 AMdacker says:
Fresh pomegranates cost about $3 each where I live. Have you tried using bottled pomegranate juice such as POM? How many ounces/ml of juice do six pomegranates typically yield? Other than "cheating" a bit, can you think of any downsides?
Jan 6, 2011. 5:21 PMribatejoluso says:
Great tut.
You can make liquor of pretty much any fruit.
This reminds me about my sys Ilda back in Portugal, who is an expert in liquors.
She uses pretty much all fruits that she can and some cereals too.
Some of those are delicious!!! others are good just for the fun,
Jan 6, 2011. 7:25 AMladybanksia99 says:
I live in a area where pomegranates are plentiful, and have found that when juicing the seeds, it is easier to accomplish this when the seeds are warmed up a little. Soaking them in warm water softens them and releases the juices better. Similar to warming citrus before juicing.
Jan 6, 2011. 5:58 AMPenfoldPlant says:
A very well written Instructable for what sounds like a delicious drink. I'm going to have to add it to my "to make" list.
Jan 5, 2011. 12:58 AMgouache says:
looks good I will give it a try but what is the shelf life? how do you store the bottles? in the refrigerator or room tempreture?
Jan 4, 2011. 4:20 PMthepelton says:
I wish I was still living in that apartment in San Diego with a Pomegranate tree outside the front door.
Jan 1, 2011. 4:50 PMjrossetti says:
Would there be any advantage or disadvantage to letting it infuse or age for longer than the prescribed number of weeks?
Jan 4, 2011. 8:06 AMScurvymcdiggle says:
you wouldn't get much benefit from longer infusing there is only so much flavor in any one item. and it really goes pretty quickly. i did strawberry once and it was done extracting the flavor after 3 days....also don't make strawberry just eat them. its not worth it.
Jan 3, 2011. 4:01 AMBoppo3 says:
Will whiskey work too? I currently don't have any vodka and I have some whiskey :P
Jan 3, 2011. 12:18 PMNatasha Dee says:
What is the shelf life of the finished product? I'm assuming you would keep it in the fridge.
Jan 3, 2011. 12:24 PMSmexy Dead says:
How cool a place should you keep it in? Would a fridge or a cabinet be preferable?
Jan 2, 2011. 11:06 AMCrLz says:
Looks awesome, should have just enough time to make some for a Valentine's Day love potion!
Jan 2, 2011. 10:38 AMscoochmaroo says:
Please send to: Scoochmaroo, 82 Second Street, San Francisco. . . .
Jan 1, 2011. 9:53 PMthe walking stick says:
I tend to add simple syrup in a ratio of 1 part syrup to 5 parts fruity vodka, and I love the idea of using pomegranates. I have not tried that fruit yet.
Jan 1, 2011. 7:48 PMP1mpy says:
This sounds like a delicious Idea!! I normally make lemonchello and I love mixing drinks that taste great when you add time!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:djeucalyptus
