Homemade Rail Gun
4,681
62
Posted
Introduction: Homemade Rail Gun
This will teach you how to build a functioning rail gun, a gun that can fire metal projectiles between two electrically charged rails using electromagnetism.
Materials needed:
2 steel or aluminum metal rails
2 plexi glass sheets
6 nuts and 6 bolts
1 drill
copper wire
6 capacitors
10 9 volt batteries
voltmeter
Aluminum foil
Step 1:
Drill 6 holes into both of the plexi glass plates
Step 2:
File the metal rails down to remove any coating and put the two rails between the plexi glass plates as parallel as possible
Step 3:
Connect the capacitors together and connect the 9 volt batteries together and create a circuit between the capacitors and the batteries to charge the capacitor. After a few minutes of connection the capacitors should be fully charged, test the voltage across the capacitors using the voltmeter and disconnect the circuit
Step 4:
Screw the nuts and bolts through the holes in the plexi glass plates and tighten to keep the rails in place
Step 5: Fold aluminum foil into and rectangular metal projectile that will touch both rails when placed between them.
Step 6: Place the projectile between the rails, connect the wire on the positive side of the capacitor to the left rail and the negative to the right. When electrically charged the two rails will create an induced magnetic field that will fire the projectile forward. FIRE!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    Is a 100 volt, 10 millifarad capacitor enough?
    Neat project!
    Do you have a video of it in action? It would be excellent to see this work.
