Homemade RepRap Prusa 3D Printer DIY X Y Axis Slide Linear Stage Frame by Aluminium Alloy
Published
Introduction: Homemade RepRap Prusa 3D Printer DIY X Y Axis Slide Linear Stage Frame by Aluminium Alloy
Materials:
Homemade X Axis Slide CNC here:
1 pcs Aluminium Alloy 240 mm x 80 mm x 8 mm
2 pcs Aluminium Alloy 80 mm x 42 mm x 12 mm
1 pcs ID6.35*8mm D19*L25 Aluminium CNC Stepper Motor Flexible Shaft Coupling Coupler Encoders Engraving Machine Coupling
1 pcs 260 mm 8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 220mm with Copper Nut
1 pcs Nema 17 42BYGHW811 0.48N.m(70oz-in) 48mm 2.5A for 3D printer
2 pcs 12 mm 12 x 250 mm linear shaft 3d printer cylinder linear rail linear shaft axis
4 pcs Linear motion ball slide units block bearings SC12UU Bore size 12mm
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
