Introduction: Homemade RepRap Prusa 3D Printer DIY X Y Axis Slide Linear Engraving Plotter Laser Frame
Materials:
1 pcs 340-8D 8mm Lead Screw Dia 8mm Lead 2mm Length 340mm with Copper Nut
8 pcs SC12UU SCS16UU 12mm Linear Block CNC Router DIY CNC Parts
4 pcs Diameter 12mm 400mm long linear round shaft for cnc parts LM12UU SC12UU linear bearing block
2 pcs Aluminium 75 mm x 75 mm x 8 mm
2 pcs Aluminium Profile 20 mm x 20 mm x 400 mm
2 pcs Aluminium Profile 20 mm x 20 mm x 340 mm
1 pcs Aluminium 115 mm x 115 mm x 6 mm for top
1 pcs 5 mm x 8 mm CNC Motor Jaw Shaft Coupler 5 mm To 8 mm Flexible Coupling OD 19 x 25mm
3 pcs Nema 17 Stepper Motor 42 mm motor
4 pcs SK12 SH12A 12mm linear rail shaft support block for cnc linear slide bearing guide cnc parts
4 Pcs 20 GT2-6 GT2 Pulley and 2 x 800 mm GT2 Belt KIT for 3D printer belt
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
About This Instructable
1,596views
10favorites
License:
More by joulethief669:DIY Axi Draw Bot 4xiDraw Robotic Pen AxiDraw Homemade Robot 3D Printer Plotter CNC Laser ArduinoHomemade Laser Engraving Plotter DIY Pen Draw Mini Machine CD RW DVD Drives Mechanism CNC ArduinoHomemade Wood Mini Lathe Collet ER11 Drill DIY Headstock Chuck Spindle Tailstock Slide Mill CNC
Add instructable to:
