Homemade RepRap Prusa 3D Printer Laser Engraving Plotter Frame DIY X Z Axis Slide Linear
Published
Introduction: Homemade RepRap Prusa 3D Printer Laser Engraving Plotter Frame DIY X Z Axis Slide Linear
Homemade RepRap Prusa 3D Printer Engraving Plotter Laser Frame DIY X Z Axis Slide Linear
X Axis DIY here:
2 pcs LMK12UU 12mm flange bearing CNC Flange Linear Bearings Flange Linear Bush
2pcs 12 mm 12 x 420 linear shaft 3d printer Cylinder Liner Rail Linear Shaft make gear 20 mm x 8 mm
4 pcs SCS12S-UU Slide Linear Bearings Motion Ball
2pcs 12 mm 12 x 400 linear shaft 3d printer Cylinder Liner Rail Linear Shaft
4pcs SK16 Linear motion ball slide units block bearings Bore size 12 mm
4 pcs aluminium alloy 20 mm x 20 mm x 400
4 pcs aluminium alloy 20 mm x 20 mm x 300
2 pcs aluminium alloy 22 mm x 12 x 320 mm
1 pcs aluminium alloy 42 mm x 12 x 480 mm
1 pcs aluminium alloy 32 mm x 12 x 450 mm
1 pcs aluminium alloy 42 mm x 12 x 450 mm
2 pcs THSL-340-8D 8mm Lead Screw Dia 8mm ,Lead 2mm, Length 340mm with Copper Nut
More Homemade Mini Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
