Homemade Scara Robot Arm Plotter Robotic Draw DIY Frame CNC Aluminium Alloy
Published
Introduction: Homemade Scara Robot Arm Plotter Robotic Draw DIY Frame CNC Aluminium Alloy
Homemade Scara Robot Arm Plotter Robotic Draw DIY Frame Aluminium Alloy 2 Stepper Motor
Materials:
2 pcs aluminium alloy 300 mm x 20 mm x 20 mm
2 pcs 42 mm Nema Stepper motor 1.8 degrees
4 Pcs 20 GT2-6 GT2 Pulley and 700 mm x 2 GT2 Belt KIT for 3D printer belt
4 pcs Linear motion ball slide units block bearings SC012UU Bore size 12 mm
4 cps SK12 SH12A 12mm linear rail shaft support block for cnc linear slide bearing guide cnc parts
2 pcs 12 mm x 700 mmlinear shaft 3d printer 12 mm x 700mm Cylinder Liner Rail Linear Shaft
4 pcs 5 mm x 15 mm x 7 mm miniature deep groove ball bearing with aluminium cover 30 mm x 40 mm
2 pcs 12 mm x 24 mm x 7 mm miniature deep groove ball bearing with aluminium cover 10 mm x 40 mm
More Homemade Mini Robotic Arm Laser Engraving Cutter‎ DIY 3D Printer Machine Frame here:
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
