Homemade Sealing Wax - EASY! PICTURES!
In this instructable I am going to show to how to make your very own sealing wax for signing documents and such. Sorry for the lengthy instructions, it is mostly pictures.
SEE MY OTHER INSTRUCTABLES FOR INSTRUCTIONS ON HOW TO CARVE A SEALING STAMP
Step 1Preparation
Preparation
Everything you need and MORE!
FABRIC HOT GLUE: It looks like hot glue, except it's white. the stuff I use is called "fabristick" or something.
DYE: Any kind of colorant can be used. I prefer RIT dye (very cheep).
BEE'S WAX: You only need a tiny bit. If you don't have this, paraffin works OK.
MORTAR AND PESTLE: You will need it for grinding the RIT dye into fine dust.
A CANDLE SETUP: It is featured in the picture below. Looks like a candle under a metal tripod.
ALUMINUM DISH (OR EQUIVALENT): Use one that is small enough to be used in the candle setup.
WORK PAPER: Something that you won't mind getting wax on. your going to work on top of it.
BEGIN!
35 comments
Jan 24, 2012. 7:00 PMTheAmateurArtisan says:
would this be flexible enough for the mail?
Sep 5, 2011. 5:28 PMdeathnotx101 says:
I've always wanted to make an old fashion letter after watching so many old movies. :) thanks for making my wish come true!!!
Aug 27, 2011. 8:54 PMjcoronel1 says:
Great tutorial. Easy to understand and really helped me make it my own. Lots of room for self editing! Also I used a small ceramic bowl to mix it all up, it took a long longer than i think it should have so i am assuming it is alot easier with a metal one?
Jul 5, 2011. 11:50 PMcrimsonhalo says:
Does the colour transfer to any other surface once the mix has been applied as a seal? Or is the glue and wax sufficient to keep the dye contained?
I'm planning on creating mailable seals, so I'm curious to hear from someone who's got more experience on this stuff.
Dec 25, 2008. 9:58 PMeranox says:
Fantastic 'ible! Great photos, and really easy to follow. Finally I can make this stuff myself without getting scammed at the store! One question, could a wick be added to the wax, or would the hot glue part prevent this from working?
Jan 19, 2009. 7:08 AMeranox says:
Y'know, I wonder if you could actually just pour the stuff into a tube the same diameter as the original glue stick, and then use the glue gun to apply it. The beeswax might make the melting point too low to pull this off, but it'd be super sweet if this works.
Jun 27, 2011. 10:22 PMbespectacled says:
Maybe if you used a high temp glue stick and low temp glue gun?
Dec 19, 2010. 7:50 AMbaronbrian says:
You might try shaving the glue into slivers some how (pocket knife, kitchen grater, whatever). That way it will melt better. You can do the same thing with wax to make it melt easier.
Sep 7, 2010. 5:41 PMOryctolagus habilis says:
Wow: what a great recipe & you can do it in any color RIT makes! I'm sure you could use standard candle-casting techniques to add a wick to the stick if you wanted to.
Sep 10, 2010. 2:09 PMOryctolagus habilis says:
Aha! Thank you for letting me know that, since I'm definitely going to make this & now know not to bother trying to add a wick.
Jan 19, 2010. 6:18 PMharmless matt says:
Really great instructable!
Any source for the pigment/dyes?
Jan 23, 2009. 3:21 AMtolga says:
very cool!How do you make the stamp?
Mar 3, 2009. 2:29 PMtjk94 says:
That's an excellent question! It says "SEE MY OTHER INSTRUCTABLES FOR INSTRUCTIONS ON HOW TO CARVE A SEALING STAMP" but I can't find that Instructable anywhere! If anyone knows where it is or why I can't find it please tell me!
Feb 11, 2009. 10:35 PMthepelton says:
Interesting. I am going to try this, and see if my Mesopotamian style roller seals will work with it. I will return with a report, but it may not be right away. I need to get the materials together. Beeswax is actually quite easy to obtain. Many small places that sell honey have small blocks of beeswax. Not the big Grocery stores, but the small places like Farmer's Markets where beekeepers sell their own personal stuff. Also, try sewing supply stores, art stores, and lumber stores. With a little digging you can find a place that sells beeswax.
Feb 14, 2009. 6:22 PMthepelton says:
I was in a hobby store just the other day, and saw a five pound chunk of beeswax there.
Feb 14, 2009. 5:56 PMMetalcaster14 says:
good instructable!
Feb 11, 2009. 10:37 PMthepelton says:
One other thing. I suspect you used the bottom of an aluminum can for your wax pan. Right? Any of them would work, as long as you made sure you didn't cut yourself on the edge.
Jan 30, 2009. 7:16 PMfilthyfury says:
i do this too but i just use a brass button for the stamp and melt a wax crayon
Jan 7, 2009. 1:14 PMjunits15 says:
will this be like real wax or is it goopy and thick?
Jan 4, 2009. 9:06 PMdenzani says:
Awesome work!
Dec 23, 2008. 12:30 PMtrooperrick says:
Great! I've been waiting for this one. Thanks for sending me the message.
Dec 25, 2008. 5:59 AMomnibot says:
I like it to :)
Dec 24, 2008. 8:52 AMERNesbitt says:
Craft stores usually carry sealing wax in large white blocks. You can use candle dye to color it. When my wife and I got married, we put wax seals on all of the invitations to the wedding. The benefit of using wax is that you can add a wick if you'd like.
Dec 22, 2008. 8:27 PMkeng says:
awesome! thanks for the i'able. now, for the obvious....what if i only have the standard hot glue (the sticks don't fit the gun I now have) and regular wax? will that work?
Dec 23, 2008. 5:13 AMfritsie123 says:
Yes, that will work also.
Dec 22, 2008. 8:19 PMCameronSS says:
About time you got this one up! ;-) Nice job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
298
Author:nepheron(MakerWeekend)
I have an awesome blog @ www.makerweekend.com Im Calvin Drews, and I love to learn, experiment, invent, create, repair, and generally just do things myself. A sort of modern jack of all trades, mast...
more »
