Introduction: Homemade Sealing Wax - EASY! PICTURES!
Picture of Homemade Sealing Wax - EASY! PICTURES!
In this instructable I am going to show to how to make your very own sealing wax for signing documents and such. Sorry for the lengthy instructions, it is mostly pictures.
SEE MY OTHER INSTRUCTABLES FOR INSTRUCTIONS ON HOW TO CARVE A SEALING STAMP
Step 1: Preparation
Picture of Preparation
Everything you need and MORE!
FABRIC HOT GLUE: It looks like hot glue, except it's white. the stuff I use is called "fabristick" or something.
DYE: Any kind of colorant can be used. I prefer RIT dye (very cheep).
BEE'S WAX: You only need a tiny bit. If you don't have this, paraffin works OK.
MORTAR AND PESTLE: You will need it for grinding the RIT dye into fine dust.
A CANDLE SETUP: It is featured in the picture below. Looks like a candle under a metal tripod.
ALUMINUM DISH (OR EQUIVALENT): Use one that is small enough to be used in the candle setup.
WORK PAPER: Something that you won't mind getting wax on. your going to work on top of it.
BEGIN!
Step 2: Candle Setup
Picture of Candle Setup
This is the heating element I used to melt the ingredients together.
Step 3: Wax and Glue
Picture of Wax and Glue
Melt a tiny bit of bee's wax in the aluminum tin. Also cut two(2) one inch lengths of fabric glue stick and put it into the tin with the melted bee's wax.
Remember: after the bee's wax melts, swirl it around the tin to thoroughly coat the inside. After you do that put the fabric glue sticks in.
If the wax bubbles or pops at any time in this procedure, it is too hot! Take it away from the flame for a minute.
Step 4: Melting Stuff = YAY!!
Picture of Melting Stuff = YAY!!
Because the fabric glue stick does not melt well without help, you may need to push it against the bottom of the tin with a toothpick. The reason it does not melt well is because of density... the not melted part of the glue stick seems to float on top of the the melted parts, keeping it away from the heat.
Step 5: Mix Mix Mix Mix...
Picture of Mix Mix Mix Mix...
Mix everything together with a tooth pick. Sort of twirl the tooth pick like a blender would (takes mad skills). When you stir it use pliers to hold the tin to keep it from moving about.
Step 6: Grinding the Dye
Picture of Grinding the Dye
Measure out about 1/4 tea spoon of dye and grind it with the mortar and pestle.
Step 7: Mixing in the Dye
Picture of Mixing in the Dye
Pour in the ground up dye into the tin of melted glue and bee's wax. I poured it all in, but I recommend pouring a little bit at a time and then mixing it up.
I also poured in copper bronze powder after I mixed in the dye. Copper bronze powder is finely ground copper (sparkles dude!).
Step 8: Prepare for Pouring
Picture of Prepare for Pouring
Now you need to get some aluminum foil. Prepare to pour the mixture onto the aluminum by heating it very hot. Leave it above the candle until small bubbles start to appear or the mixture is very runny.
Step 9: Foil Time
Picture of Foil Time
Prepare your foil by folding it into an upside down tent. Then prop it up so it won't move...
Step 10: Pouring the Wax Into a Stick Shape
Picture of Pouring the Wax Into a Stick Shape
Pour the very HOT wax into the "V" shaped piece of aluminum foil. Allow it to cool and do not move it before it has cooled.
Step 11: Removing Foil and Finishing Touches
Picture of Removing Foil and Finishing Touches
After it is cooled, do not try to remove the foil. Put it into the freezer to make the wax super cold then remove the foil. If any foil remains stuck to the wax, use an X-Acto knife to cut it away.
I also melted the bottom of the wax stick and impressed my wax seal onto it...
This wax is different to use than other varieties. Mainly it differs because it has no wick. To use this wax there are 2 ways:
1: Using a butane torch, heat up the end of the wax stick until it melts. Drip the blob of melted wax onto the object you are sealing and stamp it with you seal.
2: Cut the amount of wax you want to make a seal with and place it in a spoon. Put the spoon above a small open flame (i.e. candle flame) until the wax in the spoon melts. Drip the wax in the spoon onto the document you are going to seal and stamp it with you seal.
Have fun and be safe!
SusanD179 (author)2018-01-18
This recipe is the best I have tried to date. I found the mortar and pestle wasn't giving me good results to fine grind the Rit dye, so I used an electric coffee/spice grinder and got a perfect fine dust! I use silicone candy molds to form my wax (I had a weak moment and went for gummy bears and hearts) and store them in jars. I am going to try making my next batch in a silicone chocolate melting pitcher using the microwave. I tried using grape Kool Aid powder for getting a purple batch and it turned out so dark that my little gummy bears look brown. I will also try using dollar store eye shadows for color and shine (from the mica). I replaced the candle as heat source with a home made alcohol lamp because I hate the sooty deposit from candles. I made a small lamp for heating my spoon and a larger lamp for some serious heat for making the batch of sealing wax. Bottom line is - thanks for sharing this information.
NabiyahY (author)2017-12-31
Well it is in the freezer..I tried fabric glue (fabritack) and that melts but does not disappear. I tried to just pour the hot wax directly on the doc, but did not make it thick enough. The impression was great, but did not seal the doc.
Auryin (author)2016-09-02
Does it have to be fabric hot glue stick, can any low temp stick work?
RebeccaN4 (author)2015-08-08
Could I use acrylic paints instead of dyes?
starwarsgeek1 (author)RebeccaN42015-12-06
I crushed a lava rock into red powder and it died it perfectly fine. but acrylic wouldn't work. it was a failed attempt
AngelaL18 (author)2015-09-11
Hi guys, as the daughter of a beekeeper please let me tell you that aluminium can alter the beeswax. This may not be an issue with the small amount of beeswax in this instructional video though.
Big question... Would this be ok for sealing wine bottles??
DaYodadude (author)2015-06-16
Hey could I use a candle?
jordan.enright.35 (author)2015-02-09
You seem like a pretty cool guy! Thanks for this!
SparkySolar (author)2014-12-02
I brought over a wax stick from Europe,
I was considering casting a silicone or Air drying cast from this wax mold.
I do like to make my wax as well as my Soaps look professional
baronbrian (author)2010-12-19
You might try shaving the glue into slivers some how (pocket knife, kitchen grater, whatever). That way it will melt better. You can do the same thing with wax to make it melt easier.
SIRJAMES09 (author)baronbrian2014-05-18
and old kitchen peeler just might do the trick too....
I like your idea BaronBrian...
Sweet Jesus!! Y'All have any idea how much trouble I have caused because of this website?? *evil laugh*
But it has been a ton of fun tho...8P
nepheron (author)baronbrian2010-12-19
Thanks, I hadn't thought of that!
eranox (author)2008-12-25
Fantastic 'ible! Great photos, and really easy to follow. Finally I can make this stuff myself without getting scammed at the store! One question, could a wick be added to the wax, or would the hot glue part prevent this from working?
nepheron (author)eranox2008-12-27
No, a wick would not work .. I have tried it XD.
eranox (author)nepheron2009-01-19
Y'know, I wonder if you could actually just pour the stuff into a tube the same diameter as the original glue stick, and then use the glue gun to apply it. The beeswax might make the melting point too low to pull this off, but it'd be super sweet if this works.
SIRJAMES09 (author)eranox2014-05-17
That would be sweet...just one trivial problem tho.
What if, what if it melts the entire stick all at one time INSIDE the glue gun?
Even with a low temp gun, this is something to think about....
the possibility of the mess it could create, & how it MIGHT ruin the gun....
if you make an attempt at this, I suggest that you either...
#1) test this outside
#2) inside a box lined with old rags/newspapers
#3) One of the first two options but wearing some gloves of some kind to keep you from getting burned by the hot mixture.
Not trying to tell you wha to do, just give you something to think about B4 you do this.
bespectacled (author)eranox2011-06-27
Maybe if you used a high temp glue stick and low temp glue gun?
scammed at the store?? NAWWWWW, they wouldn't do that....
Yeah right.
They'd do it in a New York Minute....a Mississippi heartbeat...faster than you can bat an eye...etc., etc., etc......
TheAmateurArtisan (author)2012-01-24
would this be flexible enough for the mail?
easiest way to find out is to take a regular envelope, seal it like you normally would, then add the wax seal after that....once that is done, go down to the USPS & mail that envelope to yourself....if it survives their machines, then you know it's all good...the USPS might, I stress MIGHT, have a problem with the wax seal tho....were it me, what I would tell them can not be written here.... :p
Syrrah (author)2012-05-07
Hopefully, this instructable isn't dead!
I'd like to commend you for how thorough your 'ible was.
I have a question though; is bee's wax a requisite or would normal candle wax work? I see you said that paraffin is acceptable too; is paraffin synonymous with normal candle wax?
Thanks!
SIRJAMES09 (author)Syrrah2014-05-17
generally speaking, "regular candle wax" & "paraffin wax" are the same thing...
there may be a few differences between the 2, but for this project, I fail to see anything majorly different.
nepheron (author)Syrrah2012-05-07
No, it's not dead at all :)
Regular candle wax and paraffin are typically the same thing. However: regular candles might not be entirely paraffin, they might also contain a percentage of beeswax. Which is totally fine :)
Good luck!
-Calvin
SIRJAMES09 (author)2014-05-17
So if I understand you correctly, the wax by itself will not stick to the document/envelope/etc., without the melted glue that is added to the recipe?
And the rit dye is only for color?
I thank you for posting this(even if at this writing this instructable is about 6 yrs old)....I have always wondered about how these were made...
TY, it was a very enjoyable read....very educational. :)
Oryctolagus habilis (author)2010-09-07
Wow: what a great recipe & you can do it in any color RIT makes! I'm sure you could use standard candle-casting techniques to add a wick to the stick if you wanted to.
Yep, any color!
You can't add a wick, I've tried :(
The wick doesn't stay lit because there is not enough wax in this mixture fuel a flame. The only reason you add wax is to disrupt the stringy qualities of the hotglue.
nickolaiisoe (author)nepheron2013-03-11
maybe if you dip the wick in candle wax first then let it dry and then you might be able to add it and use it!?
Aha! Thank you for letting me know that, since I'm definitely going to make this & now know not to bother trying to add a wick.
nickolaiisoe (author)2013-03-11
why not normal hot glue stick
will food color do?
Graphicarmada (author)2012-07-27
Can you use normal glue sticks instead of fabric glue, and can you use paraffin instead of beeswax?
Datwinksta (author)2012-02-11
I *love* this! I think I've been using too much wax. I'm using fabric glue and bee's wax, but the sticks melt in my hands and take forever to set and the design isn't very clear...any tips?
deathnotx101 (author)2011-09-05
I've always wanted to make an old fashion letter after watching so many old movies. :) thanks for making my wish come true!!!
jcoronel1 (author)2011-08-27
Great tutorial. Easy to understand and really helped me make it my own. Lots of room for self editing! Also I used a small ceramic bowl to mix it all up, it took a long longer than i think it should have so i am assuming it is alot easier with a metal one?
crimsonhalo (author)2011-07-05
Does the colour transfer to any other surface once the mix has been applied as a seal? Or is the glue and wax sufficient to keep the dye contained?
I'm planning on creating mailable seals, so I'm curious to hear from someone who's got more experience on this stuff.
harmless matt (author)2010-01-19
Really great instructable!
Any source for the pigment/dyes?
nepheron (author)harmless matt2010-01-20
 It is Ritz Fabric Dye
It can be purchased at most craft stores, and is staple in any fabric stores.
I believe Wall*Mart stocks it, as well.
tolga (author)2009-01-23
very cool!How do you make the stamp?
nepheron (author)tolga2009-03-04
Oh, I'm so sorry! here is the link!
This instructable is pretty old... no wonder you had trouble finding it! It's also not quite as well done as my newer ones...
https://www.instructables.com/id/Homemade-wax-seals-part-1/
Good luck and tell me how it goes!
-Nepheron
tjk94 (author)tolga2009-03-03
That's an excellent question! It says "SEE MY OTHER INSTRUCTABLES FOR INSTRUCTIONS ON HOW TO CARVE A SEALING STAMP" but I can't find that Instructable anywhere! If anyone knows where it is or why I can't find it please tell me!
nepheron (author)tjk942009-03-04
-Nepheron
thepelton (author)2009-02-11
Interesting. I am going to try this, and see if my Mesopotamian style roller seals will work with it. I will return with a report, but it may not be right away. I need to get the materials together. Beeswax is actually quite easy to obtain. Many small places that sell honey have small blocks of beeswax. Not the big Grocery stores, but the small places like Farmer's Markets where beekeepers sell their own personal stuff. Also, try sewing supply stores, art stores, and lumber stores. With a little digging you can find a place that sells beeswax.
thepelton (author)thepelton2009-02-14
I was in a hobby store just the other day, and saw a five pound chunk of beeswax there.
Metalcaster14 (author)2009-02-14
good instructable!
One other thing. I suspect you used the bottom of an aluminum can for your wax pan. Right? Any of them would work, as long as you made sure you didn't cut yourself on the edge.
filthyfury (author)2009-01-30
i do this too but i just use a brass button for the stamp and melt a wax crayon
junits15 (author)2009-01-07
will this be like real wax or is it goopy and thick?
denzani (author)2009-01-04
Awesome work!
trooperrick (author)2008-12-23
Great! I've been waiting for this one. Thanks for sending me the message.
nepheron (author)trooperrick2008-12-23
Thanks for liking it!
About This Instructable
276,689views
277favorites
License:
Bio: Travelling since 2013. I'm currently in Australia for some reason. --- I’m Calvin Drews, and I love to learn, experiment, invent, create, repair, and ... More »
More by nepheron:DIY Michigan Shaped Cutting Board (video)DIY Wood Knife SheathDIY Camera Boom (Video)
Add instructable to:
